Front Axle U-Joint Replacement Question
Old Aug 2, 2010 | 09:05 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
I did an oil change and lube tonight and while I was greasing ball joints, I notice that the passenger side axle u-joint was shot. I called and ordered a new u-joint. Is the removal and the replacement of the actual u-joint completed the same as any other u-joint? I know how and have had the axles out before but never had to do an axle u-joint. Any pointers would be greatly appreciated. Thanks
Old Aug 2, 2010 | 09:11 PM
rbaker6336's Avatar
rbaker6336
Haven't had one of these apart but the older ones had the retainer clips inside the yoke,other than that it's the same
Old Aug 2, 2010 | 09:16 PM
robinsonpowerstroke
Ok cool. I know the clips aren't on the inside. Didn't really look at it hard but I assumed the clips are on the inside.
Old Aug 2, 2010 | 10:35 PM
bigbubba87's Avatar
bigbubba87
pull your wheels and brake calipers off. the lock outs have a big ring that snaps in the hub assemble its easy to get out pull the lockout out and there should be a snap ring and plastic washers on the axle shaft inside the hub assembly,take them off. the hub assembly has 4 studs with nuts on the back take the nuts off. hopefully yours will not be like mine when i first took them apart, mine were seased in and i beat and pried and cussed but finally got them out ended up putting new hub assemblys on a month later from beating on them then the bearings went out. try not to break you rubber seals that seal in the knuckle for automatic hubs but pull the hub assembly out and the axle slides right out. if your hub assemblys come out put some never sease or grease on the studs and assembly to keep them from seasing in there
Old Aug 3, 2010 | 09:25 AM
89LX306's Avatar
89LX306
Be careful pressing them out. I bent the ears on my axle pressing them out. I bent both passenger side (long and stub shaft) ears and ended up replacing the axles. Luckily I found one used and was able to buy a new stub shaft at a decent price. Needless to say what had been a smooth operation came to a screeching halt when the new u-joint wouldn't go in.
I talked to a guy at Houston Drivetrain and he said they always support the ears on the inside when pressing a u-joint out. I didn't and it bit me. Wish I would have known.
Old Aug 3, 2010 | 10:06 AM
harrington's Avatar
harrington
89LX306 makes a very good point. i've done the same thing.
i tend to smack the ujoint caps them selves with a hammer first. trying to break the corrosion bond.
Old Aug 3, 2010 | 12:46 PM
clem1226's Avatar
clem1226
Heat and penetrating oil are your friend. I like to use a propane or MAP gas torch and heatcycle the cap a couple of times. Get it good and hot then quench it with PB blaster or any equivalent penetrating oil from the opposite side so the oil is sucked up in to the cap/yoke area. Then do it again. A little patience and persistence here will pay off big time and make the day go a lot smoother.
Old Aug 3, 2010 | 07:33 PM
robinsonpowerstroke
Thanks for the advice. I have had both sides apart before to do the ball joints twice so pulling the axles out will take me about 30 mins. I just wasn't sure if the actual u-joint was just like any other driveshaft u-joint. I have replaced dozens of those. The only difference must be is that the clips must be on the inside instead of the outside.
Dean06919
Jul 26, 2016 09:28 PM
corksil
Sep 13, 2015 08:06 PM
ggwash21
2004 - 2008 F150
Sep 11, 2013 04:16 PM
rallyracer
Aug 12, 2010 09:59 AM
slidingdelta
1983 - 2012 Ranger & B-Series
Jun 26, 2010 05:43 PM
