1990 F150 Intermittent issues.
Old Jan 16, 2013 | 07:23 PM
JDaniel6's Avatar
JDaniel6
I have a 1990 F-150 with a 5.0 and 5 speed 4 wheel drive. In the past I had a problem with injector pulse not coming out of the ecm. I replaced the ecm with a junk yard ecm and the truck ran fine for about 2 months. This last week the I started the truck and drove it home from work and it seemed to have a strong odor of fuel but no smoke and the truck just had no power. Later that day I got in the truck and it drove perfectly. Since then about every other time I drive it it has this issue. I have no check engine light on but pulled codes anyway and got these. KOEO 12,51,63,44,22,41,34. KOER 52,77,34,44. About ten minutes later without resetting or driving I checked codes again and they were. KOEO 21,24,34 and no KOER codes. Anyone have any ideas?
Old Jan 16, 2013 | 09:50 PM
JDaniel6's Avatar
JDaniel6
Also forgot to mention, Whenever the self test connector is hooked up for the koer test the engine idles up to 2000rpm, Is that normal?
Old Jan 16, 2013 | 11:46 PM
AndrewW's Avatar
AndrewW
From what I have read it sounds like something on the EGR side, at least with the newest set of codes. As far as the old ones, it goes all over the board from coolant temps to power steering. Try disconnecting the battery for a little while and then driving it. It will idle/run rough for a little bit but it will even out.
Old Jan 17, 2013 | 05:55 AM
JDaniel6's Avatar
JDaniel6
I will unhook the battery for a bit and than drive it to work and post back the results tonight.
Old Jan 17, 2013 | 06:57 PM
JDaniel6's Avatar
JDaniel6
Ok so I unhooked the battery for a bit before work this morning. It drove great for the 15 mile trip to work and great for the 15 miles back. I got home and had to leave about 20 minutes later and it drove like crap again for about 5 miles untill I got back home so I checked the codes and they were KOEO 11 and 34. KOER 34, 44, 25 and 52. I also found that I have no vacuum to my egr valve and no vacuum to the egr vacuum solenoid. I guess my next step would be to find why I have no vacuum and go from there? Any thoughts or ideas?
Old Jan 17, 2013 | 10:29 PM
AndrewW's Avatar
AndrewW
My first step would be to follow the vacuum line that goes to the solenoid. If there are no leaks in the line I would then test the voltage to the solenoid to see if it has gone bad. You might want to also check the EGR valve to see if it is clogged or has allot of carbon build-up.
Old Jan 18, 2013 | 06:17 AM
JDaniel6's Avatar
JDaniel6
It must have a leak because there is no vacuum coming to the solenoid. I will check today.
Old Jan 18, 2013 | 08:23 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Try disconnecting (electrically) the EGR solenoid and see how it runs. That will likely set off your CEL, but don't worry about that for now - we're just trying to pinpoint whether the problem is EGR related or not right now.
Another possibility is a failing PCM due to leaking capacitors. I've yet to find one of this era that didn't have at least one leaking. See some of the recent threads on that topic for more info.
Old Jan 18, 2013 | 11:32 PM
JDaniel6's Avatar
JDaniel6
I will try that in the morning and see how the truck does tomorow and get back to you.
Old Jan 19, 2013 | 09:18 PM
JDaniel6's Avatar
JDaniel6
Thanks for the suggestions guys but unfortunantly I will not be needing further help with this issue due to the fact that this morning I either cracked my block, one of my heads or blew a head gasket and The truck is now down. Thanks for the help it was much appreciated.
Old Jan 20, 2013 | 09:38 PM
AndrewW's Avatar
AndrewW
What happened to it?
1988f150dude
Jan 19, 2019 07:57 AM
snurchi
Sep 7, 2010 09:05 PM
glasseater
Nov 13, 2008 09:53 PM
jhnhardee
Dec 24, 2005 06:13 AM
ctch88
1978 - 1996 Big Bronco
Nov 20, 2005 11:53 PM
