Well Guys and Gals, my scan gauge II at idle is reading EBP 18.5, IPR 9.0, and ICP 525. Chris and I were discussing it after looking at his with the scan gauge II. He thinks mine might be low on the IPR and ICP and high on the EBP. I defer to the grand knowledge. Let me know if I need to worry about anything, or check anything.
PS: I am running a diablo predator tuner on 85E. Truck is running smooth, starts right up, accelerates fine. Just curiosity.
Okay on the drive home, level ground running 70, rpm approx. 2k. EBPV sitting around 25, IPR sitting around 24, ICP sitting around 1550. Do these levels sound about right.
I didn't see any mention of the new EBP reading after the cleaning (key on, engine off). I just had an EBP read high and replacing it bounced my MPG back where it belongs. It needs to match your MAP sensor reading. My EBP was at 16.8 (bad), now it's at 14.2 (good).
Click the last link in my signature for more tips.
Thanks Tugly. Mine is running high as well. Chris and I are going to try and clean it up this weekend. After 200k, its the little things that work on the pocket book.
Okay, looks like I will be tearing into the EBP this weekend, if the weather holds out. Maybe it can all be cleaned out. Maybe I need a new sensor and tube. We shall see.
Well this morning after receiving a new sensor, I figured that I would try cleaning the old sensor and wow that thing was full of soot. I cleaned it up and put it back on and the EBP reads 14.5 KOEO. Sits around 15 idling. I will keep the other sensor and change it out the next time or have it on hand in case someone else needs it.
