Scan gauge readings
Old Jan 26, 2013 | 05:05 PM
Tugly's Avatar
Tugly
It sounds like you're there. Good Job! The EBP needs to match the MAP within 0.2 PSI on KOEO. That's according to the Ford manual.
Old Jan 26, 2013 | 06:02 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Tugly, how do I program my scan gauge II to read the MAP sensor. I don't find the setup for that in my x-gauges codes.
Old Jan 26, 2013 | 06:27 PM
honeydew's Avatar
honeydew
Ted, MAP should be one of the preprogrammed gauges. The boost x-gauge uses a formula to subtract your inputted constant barometric pressure from MAP to derive turbo boost.
Old Jan 26, 2013 | 07:11 PM
twg1966's Avatar
twg1966
I will double check, but I don't remember seeing that one as an option.
Old Jan 26, 2013 | 09:43 PM
honeydew's Avatar
honeydew
I checked mine and it is there, don't recall programming it but I will look into it more tomorrow.
Old Jan 27, 2013 | 07:35 AM
twg1966's Avatar
twg1966
Thanks Honeydew. I just need to get all the settings figured out. Lots of great info on the scan gauge.
tcjhkbjt
May 16, 2015 09:53 PM
HKmnU97
Nov 19, 2014 05:57 AM
DanielT28
Sep 3, 2012 08:15 PM
ccarrier
Apr 14, 2011 10:39 AM
Farmboypowerstroke
Mar 11, 2010 05:13 AM
