Sponsored by: Real Truck
overheating problem
Old Jan 15, 2013 | 07:25 PM
Sickler1's Avatar
Sickler1
overheating problem
I have a 2003 f250 5.4.....my problem is, my temp sensor gauge will shoot to hot will go into safe mode and blow coolant out of reservoir tank.now I do get smoke behind truck but I don't know if it's outta tailpipe or just coolant hitting exhaust.well all this happens I'll turn my truckoff then back on n it will be fine.this happens bout once a week.
Old Jan 15, 2013 | 08:03 PM
Bigpipes 35's Avatar
Bigpipes 35
There was just a thread in the excursion forum and the guy had the exact same symptoms. It was his thermostat and what we learned from that thread is only replace it with a genuine ford stat.
Old Jan 15, 2013 | 08:25 PM
dlibson's Avatar
dlibson
Well being Ford t-stats are made by the same company that supplies most part houses that's not always the case. Could be he just got a bad one.
I've replaced a handful of temp sending units with these symptoms and have done t-stats as well. Could be either one...
Old Jan 15, 2013 | 08:32 PM
Sickler1's Avatar
Sickler1
I did put a new failsafe thermostat in...think I should put a factory one in?
Old Jan 15, 2013 | 08:36 PM
dlibson's Avatar
dlibson
You can try it. The failsafe brand is not good. It's an import one, and have problems. Get a Stant branded one, or OE. Same thing...
Old Jan 15, 2013 | 08:51 PM
Bigpipes 35
If I remember correctly he put in 3 or 4 aftermarket stats all of which were different manufactures and they all failed. He put in an oem one and problem solved. Thats enough evidence for me to to not waste my time on a parts house stat.
Old Jan 15, 2013 | 08:53 PM
Bigpipes 35
Without a doubt...
Old Jan 15, 2013 | 08:55 PM
Yahiko's Avatar
Yahiko
Give these guys a call they support the site and are very good
and the prices beat almost everyone out there
Tousley Ford Parts Depot
This way you get a GOOD Ford pard not some Chinese crap
from the local auto parts box store.
Sean
Old Jan 15, 2013 | 08:58 PM
dlibson's Avatar
dlibson
That could be depending on where they came from. I use nothing but aftermarket Stant in anything. Being a mechanic, I do a few too. But the Advanced and AutoZones of the world use garbage. If you buy a good one, it's likely from an OE supplier anyways.
Old Jan 15, 2013 | 09:05 PM
Bigpipes 35
Here is the post I was thinking of. He shows the diference in the stats and does a boil test on them as well. Update; Radiator spewing and limp mode fixed, with pictures.
Old Jan 15, 2013 | 09:09 PM
dlibson's Avatar
dlibson
It doesn't even look like the right t-stat, that aftermarket one. Wonder what brand it was?
Old Jan 15, 2013 | 09:13 PM
Bigpipes 35
I am not sure on the brand, this was a very long thread and he posted about the problem at least 3 times. If I get really bored tonight I will try to sift through his posts and see if I can find a brand.
Old Jan 15, 2013 | 09:15 PM
dlibson's Avatar
dlibson
I can imagine! No worries on finding it, not a huge deal just curious.
To the OP, sorry for the thread hijack! LOL
Old Jan 15, 2013 | 09:56 PM
Sickler1's Avatar
Sickler1
No biggie...just hoping it's my thermostat
Bsentman888
Feb 2, 2013 09:52 AM
Blakeb4988
Sep 23, 2010 05:09 PM
dscofever
Mar 23, 2010 05:49 PM
someday
Nov 17, 2004 06:12 PM
robomanjohn
Jun 23, 2004 09:40 PM
