Sponsored by: Real Truck
Need help
Old Jan 15, 2013 | 08:08 AM
WorkhorseF250's Avatar
WorkhorseF250
Need help
Specs
2006 f250 5.4l 3v
287000 kms on the clock
She's starting to make some noise in the front, idling and when Erving up, it can be heard on the highway, it sounded like the power steering, but I have ruled it out. By chance can the fan make a constant similar whine that the power steering does, it's not quite that similar but it's the best way to describe it. I pulled into the parking lot this morning and it was making a rattling/ticking noise, then it stopped when I revved it up a bit. Any ideas would be great thanks
Old Jan 15, 2013 | 02:04 PM
Yahiko's Avatar
Yahiko
Alternator, Water pump and some idlers.
Take a long screwdriver and place your ear on the handle
put the tip on or near each item and listen to the sounds.
Alternators can make a bad squeal as the bearings go.
The water pump will tend to have a tiny bit of leakage
at the weep hole. So if you can see it and check for stains.
Idlers you may be able to test by removing the belt and giving
then a spin and also see if they have any side play.
While your doing all of this when you have the belt off if it's
been some time you may as well replace that.
Sean
Old Jan 15, 2013 | 04:08 PM
Kdr358's Avatar
Kdr358
Worst case, Cam phasers, failed timing chain tensioner, or worn guides. I would start with the above. I had an idler go out on my 03 Crown Vic and it sounded like the engine had major problems.
Old Jan 15, 2013 | 06:13 PM
WorkhorseF250
well alittle investigating and found that the belt tensioner pulley bearing seized and broke in which case it rolled the pulley around wearing it away... getting it fixed right away, gotta say tho, my truck has yet in the 5 years ive owned her never let me down she just keeps on going and getting me home.
thanks for the help all and will post some pics soon of the damage for future ford owners to use.
Old Jan 17, 2013 | 12:22 AM
WorkhorseF250
well with the tensioner Replaced and new belt on the truck is running great! thanks to everyone that threw ideas my way its greatly appreciated, its interesting as to how much that tensioner actually affects, like the truck feels alot better then it did prior to the tensioner failing.
Old Jan 17, 2013 | 03:04 AM
Yahiko's Avatar
Yahiko
Thank You for reporting back that you found and fixed it.
This may help someone else some time.
Sean
can0fspam
17
Oct 7, 2018 07:22 PM
GHeTTo JOe
Mar 10, 2013 04:31 PM
Ford Jade
2004 - 2008 F150
Dec 4, 2011 11:20 PM
mediaman67
Aerostar
15
Jan 10, 2006 09:27 AM
cooky
Jan 6, 2006 06:00 AM
