Oil Change Reset
Old Jan 14, 2013 | 08:49 AM
Adventure Rider's Avatar
Adventure Rider
Oil Change Reset
Need some help on resetting the oil change message
Yes - I did RTFM but it does not match the information I am seeing
- Standard gauge cluster
The manual says press and release SETUP button to Oil Life XXX%
Problem 1 - i do not have this message
The manual says press and hold reset button for 2 seconds to reset to 100%
Problem 2 - the reset button press for much longer than 2 seconds - does nothing
Any help here would be appreciated
Old Jan 14, 2013 | 09:19 AM
Painted Horse's Avatar
Painted Horse
Cycle your menu thru till you come to the System Check section.
Choose the Oil Life section
Press and hold the OK button to reset.
Old Jan 14, 2013 | 10:11 AM
djousma's Avatar
djousma
PH, looks like he has the standard cluster, no productivity screen. Maybe one of those guys will pipe up.
Old Jan 14, 2013 | 10:24 AM
donovan's Avatar
donovan
Reset oil life
I have the standard screen. Get to message that says change oil, and hold the reset button down until it changes. Then answer yes to the question.
I have only done this once,
I think you get to the message by hitting top button which is setup then the bottom button which is reset.
Old Jan 14, 2013 | 11:18 AM
Adventure Rider
That's right no productivity screen
thanks will give that a shot later
Old Jan 14, 2013 | 11:50 AM
wtrlogd's Avatar
wtrlogd
The trick is hitting the upper "setup" button twice, that gives you the screen with the message to reset oil life to new.
Old Jan 14, 2013 | 12:07 PM
Adventure Rider
Thanks - so what would be the button sequence
Right now it is
Select change oil
Press reset until questioned
Answer question
Old Jan 14, 2013 | 12:27 PM
wtrlogd's Avatar
wtrlogd
Not sure what you're asking, but I know in the past I spent a lot of time hitting the three buttons and never getting to the right screen.
As you push the setup button (only) it toggles through a variety of things you can change, the first being "hold reset=new", hold reset a few seconds till the screen says its been reset. The "info" or center button takes you out of the menu.
Old Jan 14, 2013 | 12:45 PM
Adventure Rider
Me too
Guess I will try a few things!
Old Jan 14, 2013 | 06:24 PM
Adventure Rider
All Set!!
Fully reset
Thanks to Donovan and Wtrlogd
I cant remember exactly what I did as it happened to fast I was in the Set to New before I knew it but it was a combination of both
Enduroman
Jun 13, 2017 09:52 AM
bridgeman
6.2L V8
Apr 24, 2015 06:57 PM
Pit Crew
Feb 12, 2015 11:32 AM
baker51
Apr 11, 2014 04:27 PM
burrhead
6.2L V8
Jul 9, 2011 12:12 AM
