Ok so i am doing my upper and lowers of corse, I am to the step where i am trying to take the axle out, i am trying everything, prying on it, hitting it, that seal seems stuck on there and will not budge. Does anyone know what i am talking about and may know a trick, i was thinking of heating the outside of the housing deal i do not know what it is called lol. do you think that will loosen it up? anyways here is pics o what i am talking about. thanks for the help/
Awesome man i will give it a try tomorrow, i was getting frustrated and called it a night lol. well i do not have new seals i hope i will beable to pick up new ones tomorrow... i wishe di didnt work all the time id have time to get parts ha. this wasnt even suppose to be a ball join job just breaks then i noticed they was bad so here i am haha
There was a Bunch of Pics looks like all the Pic Links are Broken
It was a GREAT Writeup still is just Minus the Pictures
You will need to make the Seal Install Tool
Its Picture was still in there in the Link above for the special tool to Install the seal when going back together
Yes you can get NEW Seals
I bought ALL New seals But the 2 Main ones like in your pic Usually Break for me 1 Broke 1 was reusable but I installed 2 new ones
Ford will have them get them all there is 4-5 per side
But thats the Main Ones in your pics 50-70.00$$ Each FYI so Not cheap
have a good weekend
Yes can be Frustraighting as Hell
I Never Beat a Auto that hard Before to get apart
I did mine thought I would save a Penney but spent around 600.00 in parts and special tools Pullers and what Not
The Cool thing I Guess is next time it will be cheaper Lifetime warrenty on MOOG BallJoints and I have the tools!! Just have to Buy the seals
I went Moog Balljoints since they was Greasable and Lifewarrenty so far so GOOD
Good Luck Let us know if you get Stuck again I Know some them Parts can be Rusted together and tough to get apart
So Give a shoutout if you Get to a Bad spot again
I know I read the writeup Many Time just to be Shure I was doing it write Since I beat it so Hard to get apart I know its scarey LOL
Hey Isn't this it? i know it is more expensive but i have to have my truck today i need to go to work tomorrow so if this is the same i will buy this one.
<p>Take a 5 pound hammer and smack the yoke of the axle where the ball joint goes through on the front and back side and alternate back and forth hitting front then back and then with the nut on flush on the bottom ball joint stud smack the top of the stud with the 5 pound hammer. They can be a bear to get loose but they will come. A bit of kroil or penetrating oil can help as well.</p>
Ok i got it i got a pully puller and put pressure down on the upper then hit the lower and the kept tightening it and ban she cam out,,, thank you all for the help i finished finally. uhm only thing now is my steering is really tight and wonders a bit??
[quote=95PSDieselP;12710994]Ok i got it i got a pully puller and put pressure down on the upper then hit the lower and the kept tightening it and ban she cam out,,, thank you all for the help i finished finally. uhm only thing now is my steering is really tight and wonders a bit??[/quote]
Ok Cool you got it
The way all these BJ and steering Componet are Taper Fit they shure can be troublesome
The Tool I posted you drive in just to Separate Steer knucle from Axel Tube Ears Next time
I had to get all Kinda Pullers it sucked
Well I hope you used a Torq Wrench and Followed the Torq Sequence on Balljoint Nuts Cause Over Torq could have a Effect on this
They May loosen after a few drive
Did you Grease the BJ Zerts???? (Hope you got servicable BJ)
