Fixer up-per
Old Jan 10, 2013 | 06:29 PM
brandon.edwards's Avatar
brandon.edwards
Fixer up-per
So as i have been researching and saving cash for repairs, my truck doesn't like to start after i have warmed it to operating temps. I have come to the UNOFFICIAL conclusion, I have either bad injectors, FICM, or high pressure oil leak. Or, i have all three
Old Jan 10, 2013 | 06:37 PM
steelhead2's Avatar
steelhead2
My moneys on a hpop leak. Theres various tests and troubleshooting steps in the tech folder.
Old Jan 10, 2013 | 06:40 PM
brandon.edwards
ever heard of Bill Hewitts Powerstroke help.com? Anyone ever had anything fixed there?
Old Jan 10, 2013 | 07:10 PM
RideDiesel88's Avatar
RideDiesel88
Need more info on your truck. Im guessing you have a late 04 build. Sounds like a HPOP problem. Did it just start happening??
Old Jan 10, 2013 | 07:16 PM
william_04_x's Avatar
william_04_x
A lot of us have heard of him. I don't remember reading about many here who have had him do work on their trucks. I can't stand his videos, myself.
Agree with others that you probably have a HPO leak.
Old Jan 10, 2013 | 08:26 PM
brandon.edwards
Yea me neither. He wants people to ship trucks to him, good business idea, but i like to talk face to face with MY mechanic. But to answer your question RideDiesel88, Its been SLOWLY getting worse. The starts are harder and harder unless i have her plugged in, in this colder weather especially. Even if i warm her up before i take off its still rough until i get into er a little bit. I have an SCT tuner using canned tunes, but until i give er more throttle she runs like a bag of poop. So its injectors, ficm, and hpol. Maybe one, maybe two, maybe a combo of all 3?
Old Jan 10, 2013 | 09:22 PM
RideDiesel88
You need some gauges for future reference. Helps narrow stuff down. I got gauges all over the place. you cant have too many gauges. They help me sleep GOOD at night! haha
Old Jan 10, 2013 | 09:26 PM
brandon.edwards
What gauges do u reccomend/ have.
Old Jan 10, 2013 | 09:47 PM
RideDiesel88
SGII with 6.0l program will cover more than you can think of. Then i got a fuel pressure guage, trans temp and boost psi gauge. SGII doesnt read fuel press or EGTs. Im looking into coolant psi gauge to tap into coolant filter and oil psi to tap into filter housing or somethin. My point is, you cant have too many gauges.
Old Jan 12, 2013 | 12:06 AM
SHOOTER22250's Avatar
SHOOTER22250
My bet is on the injectors being sluggish.
Get some Archoil 2300 and run for 5000 miles then use the Archoil 9100 in the future if the 2300 clears up or helps the problem you are encountering.
You should see a diffence in a short time when running the 2300 if it is the injectors.
Old Jan 12, 2013 | 03:04 AM
Yahiko's Avatar
Yahiko
FTE Remembers
For testing you need to set it back to stock and remove the tune
for testing. And I also think HPOP leak.
Have a look in the tech folder for the issue
that you dealing with.
Sean
Old Jan 12, 2013 | 12:36 PM
MisterCMK's Avatar
MisterCMK
How is stiction going to affect a hot start?
Old Jan 13, 2013 | 02:38 PM
brandon.edwards
Anyone know where the best place is for getting the FICM that i want. Does it need to be Ford/Motorcraft?
Old Jan 13, 2013 | 04:00 PM
Yahiko's Avatar
Yahiko
FTE Remembers
FICM Repair.com - Your Source for FICM Repair
Best place for any FICM work
Sean
Old Jan 13, 2013 | 04:44 PM
tr0y's Avatar
tr0y
I second ED the FICM Fixer ... ficmrepair.com Good work, quick service love the atlas 40, seems expensive, until you need to do it twice.
