IPR?
Old Jan 12, 2013 | 08:40 PM
Roasted7's Avatar
Roasted7
I sometimes wonder if the ICP being located under the turbo is getting to hot. The excessive heat causes the voltage to fluctuate.
Old Jan 12, 2013 | 08:45 PM
vloney's Avatar
vloney
Originally Posted by Roasted7
How can you just lose the KAM for the VGT? And why only on long road trips?
  1. TURBO LEARN PROCEDURE:
  1. NOTE:
THE VGTDC WILL BE COMMANDED TO VARIOUS LEVELS DURING THE LEARN PROCESS CAUSING CHARACTERISTIC TURBO SPOOLING NOISE. THIS NOISE IS NORMAL.
  1. Clear the KAM by disconnecting both batteries for 5 minutes.
  2. Reconnect both batteries.
  1. Start the vehicle and let the vehicle idle. If the conditions below are correct, the learn will occur automatically.
  1. NOTE:
DURING VEHICLE IDLING, MONITOR PIDS VGTLRN_OK AND VGTVP_LE. ONCE THE PCM HAS LEARNED, THE VGTLRN OK PID WILL READ -YES- AND THE VGTVP_LE WILL BE AT 6 OR HIGHER. IF NOT, MONITOR PID VGTLRN_CNC. IF THE PID READS -YES- THEN THE CONDITIONS ARE NOT CORRECT FOR THE PCM TO LEARN. THE REQUIRED CONDITIONS ARE:
  • EOT between 120-250° F (49-121° C).
  • Idle speed between 570 to 780 RPM.
  • VSS reading less than 2 MPH (3 Km/h).
  • APP below 1.5%.
  • EGR is commanded off (EGRDC = 0).
  • No hard fault DTCs.
NOTE:NOTE: IF THE ABOVE CONDITIONS ARE NOT MET, THE PCM WILL NOT LEARN THE NEW VGT STRATEGY.
Old Jan 12, 2013 | 08:51 PM
Roasted7's Avatar
Roasted7
  1. NOTE:
  1. NOTE:
  • APP below 1.5%.
My VGT is working good. I know the relearn process and have been through it many times. I'd just like to know how you could just "lose" the KAM while driving down the highway. And why only the VGT and not the tranny?
Old Jan 12, 2013 | 08:53 PM
DieselVol's Avatar
DieselVol
Thanks, will give it a whorl.
Old Jan 12, 2013 | 08:59 PM
vloney's Avatar
vloney
Its not the KAM, just the vgt learn. Happens when one or more of the previously mentioned perameters get out of spec. The vgt will be working well. Its the programming thats the concern.
DieselVol's Avatar
DieselVol
The problem is so intermittent that it'll be hard for me to know if this helps or not.
Old Jan 13, 2013 | 12:16 PM
DieselVol's Avatar
DieselVol
Matt and the IPR
Anybody know how Matt's tunes affect the IPR? If closed, I figure the state of the IPR screen does not matter. If open, I guess the screen does matter.
Old Jan 13, 2013 | 12:43 PM
dukie1877's Avatar
dukie1877
I think its a good idea to always have the screen on the IPR and be clear of debris
Old Jan 13, 2013 | 12:55 PM
DieselVol's Avatar
DieselVol
If it's closed, is anything going through it?
Old Jan 13, 2013 | 01:01 PM
dukie1877's Avatar
dukie1877
the IPR controls the high pressure oil going to the injectors so no matter what kind of tune you have it has to open and close all the time. If it was fully closed all the time or open all the time there would be no reason to have a gas pedal.
Old Jan 13, 2013 | 01:07 PM
retiredinstructor's Avatar
retiredinstructor
my own experience with ipr was same as yours idle would roll actually sudn surge only when outside temp reached high 90 to 100 or more . dealer chased problem for 5 years with no luck . truck is 2004 late 6.0 egr delete new oil cooler new turbo etc . long story made short every year towed 12000 lb 5th wheel to mexico 8 years in a row every time outside temp exceeded 90 degs idle would roll . i constantly monitered ipr and noticed % would jump 20% or so every time idle surged . i replaced ipr valve and problem solved for 2 years now old valve was clean and insulation pack was good and re used on new valve.i beleive valve was binding from excessive heat . good luck with your problem let us know if you solve it
Old Jan 13, 2013 | 01:15 PM
DieselVol's Avatar
DieselVol
I agree that the problem seems to be heat related. Whether engine temp or air temp determines it, I'm not sure. It could be that the higher air temp leads to higher engine temps and thus the problem. It will be interesting to see if my new external oil cooler takes care of the temp problem and thus the rolling idle problem, both at the same time.
Old Jun 20, 2022 | 02:57 PM
  #28
ajn007's Avatar
ajn007
1st Gear
My Truck currently has the PID saying conditions are not met to relearn. I've checked your items below if they are being met and they all are. The only one I'm not sure of is hard DTC faults. The only faults I have is a software incompatible with the FICM.
Old Jun 24, 2022 | 12:37 PM
  #29
olecarguy's Avatar
olecarguy
I suggest you start your own new thread.Include copy and paste of the table they provided. This one is nearly ten years old and I don't see any of the highly knowledgeable members in it.
joe blow
Sep 4, 2015 12:53 PM
osu711
Jan 12, 2015 05:44 PM
SuperDutyDoug
Sep 10, 2014 02:32 PM
96powerstroke
May 15, 2013 06:12 PM
aocabrown
20
Jan 4, 2008 11:06 AM
