IPR?
Old Jan 12, 2013 | 03:48 PM
DieselVol's Avatar
DieselVol
IPR?
About to tear the top off of the engine again and just happened to have one of those episodes where it has the rolling idle after a long interstate run. I was reading about how IPR valve problems can cause rough idle when hot, among other issues. Can an IPR problem be JUST the rough idle or does it need the starting issues as well? I bought the truck new and it's done this periodically for 10 years next week.
Old Jan 12, 2013 | 07:11 PM
Roasted7's Avatar
Roasted7
My 03 does exactly the same thing only after a long interstate run. Brand new IPR, ICP, FICM, 8 injectors has not solved the problem.
I was thinking that maybe it could be the exhaust back pressure sensor, but the stock Ford strategy that I have has that sensor written out and uses inferred values instead from what I understand.
If you figure it out, I'd definitely like to know what it was.
After a couple years I've finally just considered it to be the character of the truck and stopped worrying because it runs great otherwise.
Old Jan 12, 2013 | 07:36 PM
DieselVol's Avatar
DieselVol
Well dang! I was hoping to get a real answer some day. This has been a major annoyance for a long time now. My HPOP got replaced over a year ago and it stopped for 6 months or so. I thought that must have been the problem. Unfortunately, it started back and will now occasional do it when it's not been run all that far. I think that may be due to my blocked oil cooler causing higher engine temps much faster than usual. We'll see in a few days when that gets replaced.
Old Jan 12, 2013 | 07:39 PM
Roasted7's Avatar
Roasted7
Hate to say it but, replacing my blocked oil cooler changed nothing other than my oil temp.
Old Jan 12, 2013 | 07:41 PM
DieselVol's Avatar
DieselVol
Yeah. I didn't think that would help the rolling idle.
Roasted7's Avatar
Roasted7
I do have on theory that I haven't been able to prove or disprove just yet that has to do with airrated oil. Like maybe the level was to high.
Old Jan 12, 2013 | 07:46 PM
DieselVol's Avatar
DieselVol
I HAD an IPR theory, now dashed.
Old Jan 12, 2013 | 08:09 PM
vloney's Avatar
vloney
Dirty turbo or egr valve (because of the inferred strategy). Take your batteries loose for a couple of minutes, start it up (operating temp), let it idle for 5 minutes at least.
Old Jan 12, 2013 | 08:13 PM
Roasted7's Avatar
Roasted7
I cleaned my turbo and I have an egr delete. No change.
Old Jan 12, 2013 | 08:15 PM
DieselVol's Avatar
DieselVol
EGR delete, had the turbo taken apart and cleaned several years ago with no changes. I'll try the battery thing after the external oil cooler gets done this week. Thanks.
Old Jan 12, 2013 | 08:18 PM
cheezit's Avatar
cheezit
most common is icp voltage input is bad. have also seen pumps, ficms and injectors do te same.
vgt can cause an engine surge of around 200-300 rpm.
concern when speed contol is activated can be normal
Old Jan 12, 2013 | 08:20 PM
vloney's Avatar
vloney
The egr delete doesnt help. Its more the procedure than anything. The problem is because you've lost the "VGT learn". Your pcm is searching for the proper place to set the vgt vanes at the particular engine speed that you're operating at. Thus the "surging" that you're experiencing. EGR is a major contributor to this strategy.
Old Jan 12, 2013 | 08:24 PM
Roasted7's Avatar
Roasted7
How can you just lose the KAM for the VGT? And why only on long road trips?
Old Jan 12, 2013 | 08:25 PM
DieselVol's Avatar
DieselVol
Mine won't roll nearly that bad. When running well, the idle will be from 650 to 660 with no audible change. When NOT running well, it will roll from the 630s to the 670s and is noticeable enough that "non truck people" ask me what it's doing.
Old Jan 12, 2013 | 08:28 PM
Roasted7's Avatar
Roasted7
When I watch the scan gauge, the only thing that jumps around is the IPR duty cycle. VGT looks pretty good.
