General Automotive Discussion
TPMS (EZ Sensor)
Old Jan 10, 2013 | 08:36 PM
Sydeshow's Avatar
Sydeshow
TPMS (EZ Sensor)
Hey guys im not sure where the heck to ask this, but Ill ask here. I recently came across 4 EZ sensors that replace the band or OEM Valve Stem TPMS Sensors.
I would like to activate them to a certain vehicle now while I am working at a shop that has the little remote that will activate them.
But, the tires I want to put these sensors in are 2 hours away at my rents place for storage for the winter.
I am wondering do they run off of a battery inside? or do they run off a chip that gets programmed to the vehicle once the truck is set into TPMS Learning Mode?
My main concern is, if I activate them now, if they do run off a battery, will the battery die out cuz they are activated? or would it have to be working with the truck for the sensor battery to be used.
Old Jan 10, 2013 | 08:54 PM
JWC 3's Avatar
JWC 3
TPMS batteries "should" last 6-10 years . They do have a battery that powers them . Shelf life ??? Many stories there . VDO makes one claim , Ect .They suposidly only report every so often . If in storage they go in sleep mode . Find a tire shop you trust and do more research . Good luck !
Old Jan 10, 2013 | 09:56 PM
04XLTRUNNER's Avatar
04XLTRUNNER
I would stick with oem tpms sensors
Old Jan 10, 2013 | 10:33 PM
JWC 3's Avatar
JWC 3
Good advice , But ( there is always a butt in the crowd ) there are some aftermarket OEM producers in the market now . They made the OE units , now they offer them "after market " Look into it . Cheaper , OE Quality .
Old Jan 10, 2013 | 11:15 PM
04XLTRUNNER
Ill look into it. Won't be needing anything like that for a while though. I still have plenty of warranty. Would the tpms sensors be covered under the powertrain warranty or the regular 3/36.
Old Jan 10, 2013 | 11:25 PM
JWC 3's Avatar
JWC 3
I am not aware of the warranty on TPMS . There are a lot or factors involved that can damage them . Good question , I will look into that .
Old Jan 11, 2013 | 12:30 AM
androcathr's Avatar
androcathr
ArmamentDawg
2015 - 2020 F150
46
Jan 11, 2019 07:16 AM
Mr. PC
2004 - 2008 F150
May 7, 2010 10:29 PM
ryan70asu
2004 - 2008 F150
29
Aug 27, 2009 09:03 PM
nmcqueen469
59
Dec 20, 2007 10:49 PM
KS Country
Electrical Systems/Wiring
Nov 4, 2007 08:31 AM
