disconnect battery to change ambient temp sensor?
Most all mechanical publications mention to disconnect the batt prior to doing any electrical procedure...now with that being said,I cant for the life of me see why you should have to do it in your case.
As long as the Ignition switch is in the off position,my take on it is just "make it happen"...It would probably take longer to unhook the battery than it will to replace the sensor.
Absolutely. The forum was down this morning before I went to work, so I couldn't read your post, but I put the sensor on without disconnecting the battery. No problemo.
For anyone with a faulty sensor, I got mine online for $15.77 including shipping, and the replacement job was as easy as changing a light bulb.
PC
PC
Here is the link to the temp sensor-
2004 FORD F-150 Ambient Air Temperature Sensor
On my '06, it is standing right out in the open, just in front of the radiator when you open the hood.
I think, on some others it is not so out in the open. Either way, I think it is in front of the radiator.
When you go to the link for the part, you will be able to get a picture, I think. Then you will be able to see what it is looking under the hood.
Here's a link to a photo of the part.
http://info.rockauto.com/getimage/ge...80-0&width=450
Ive used their parts for no less than 25 restoration projects,and never had a complaint......
Roader
07-27-2023 01:50 PM
reamer
Escape & Escape Hybrid
02-22-2017 09:01 AM
El Campo
06-26-2016 12:31 PM
