Master Cylinder Question
Old May 27, 2003 | 02:22 PM
51dueller's Avatar
51dueller
I'm in the process of mounting a manual dual master cylinder (just removed the booster because it was too big). I found a bracket that the cylinder bolted onto with a hole in the middle. When the bracket is verticle the the booster is on a 45 degree angle but when I place it on the edge of the crossmember it is perfect. The booster levels out and all I need to do it do a little grinding and weld it on. Will this master cylinder power disc brakes? It came off a '73 Ford Ranchero with 11" discs. I think I will steal the porpotional valve too. I still need to find out if this bracket is still needed for something else.
Old May 27, 2003 | 08:48 PM
BlueOvalRage's Avatar
BlueOvalRage
Nathan, I think you answered your own question. If the donor car had disc brakes, there's no reason it won't work with them again. You will have to use the prop valve, though.
Old May 28, 2003 | 09:35 AM
51dueller's Avatar
51dueller
I just wanted to be sure since I will not be using the booster part of the setup. I will use the porportinal valve.
Pappys53
Jul 9, 2011 03:37 AM
Papa'sPride
30
May 4, 2010 07:43 PM
rc1099
Sep 3, 2009 12:11 AM
WIF250
May 1, 2007 11:41 AM
jdbanks
Nov 8, 2006 06:42 AM
