possible purchase
Old Jan 11, 2013 | 04:04 PM
66with352's Avatar
66with352
Thank you Bill. I will call them
Old Jan 13, 2013 | 04:50 PM
arctic y block's Avatar
arctic y block
So did ya get the steps? How much?
Old Jan 13, 2013 | 05:25 PM
66with352's Avatar
66with352
Calling them in the morning. I'll let ya know. Since we are on bed talk....Anyone know where to find the front bed cross member for a 1966 8' flareside? The middle and rear are good, however, the front on mine has both ends rotted. Looks tough to fabricate because of the twist the channel has at the ends.
Old Jan 13, 2013 | 05:36 PM
daveengelson's Avatar
daveengelson
Purchased a set of fenders for the 65 flareside and very disappointed in the gage of the sheet metal, bout the thickness of a beer can, can't apply very much pressure on the fender. Subsequently came across a very reasonable body/weld shop who quoted price for restoring the original fenders cheaper than cost for replacements. Imagine of particular concern with the step being subject to weight and heavy use? If decide on going with replacement may want to call supplier. Found best to avoid direct metal to metal contact between step, fender, and bed due to rust.
Old Jan 13, 2013 | 05:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 66with352
Anyone know where to find the front bed crossmember for a 1966 8' flareside? The middle and rear are good, however, the front on mine has both ends rotted.
C4TZ-8310610-A .. Front Crossmember-Use with 8' Flareside & 9' 1961/66 F350 Flareside Beds) / Obsolete
Applications: 1961/72 F100/350 / No Ford Dealer or obsolete parts vendor has any.
Try Mar-K (mar-k.com).
Old Jan 13, 2013 | 06:16 PM
66with352's Avatar
66with352
Thank you again. I will check with them !!
Old Jan 13, 2013 | 06:50 PM
schoo's Avatar
schoo
Originally Posted by Macs1964F100
Check the cowl vent in front of the windshield and inside the floor vents for leaves and straw. They may have accumulated and caused rust in both areas. I used a ruler to push the leaves from the cowl to the vent then vacuumed them out. You will need to take the vent dampers off to get all the leaves and mulch.
That was the only rust on my truck. It is repairable.
I bought one(front crossmember) in June from NPD
Part #f010610-4b it was on back order for 3 weeks so I fab up one from
The last one to go in front and when the one that I ordered
Came just put in last
Old Jan 13, 2013 | 07:13 PM
66with352's Avatar
66with352
Schoo - Thank you for the info but that front crossmember part # f010610-4b from NPD applies to a 80-87 F150. Did you fit that into a 66 8' flareside ?
Old Jan 13, 2013 | 10:19 PM
schoo's Avatar
schoo
If you have NPD cat look on page 201
Crossmember front f250-f350 53-72 8' bed part #f-010610-4b
My cat says $44.95 they charged me $99.25 +ship
No holes in crossmember
And yes it does fit my 8' flare side mine is a 63'
Old Jan 13, 2013 | 10:28 PM
schoo's Avatar
schoo
Forgot to say looking at invoice order in June got the member in August
So 2 months on back order
Old Jun 29, 2013 | 11:03 PM
denny boy's Avatar
denny boy
well i havn't had alot of time lately to do anything between work and side work. and getting my other car ready for car craft. The truck does have the 8ft bed and the 4 speed. I havn't had time to get it into the garage to do some vacuuming and dissasembly to see all the rust. as far as ive seen there is only acouple spots but are actually pretty bad but fixable for sure.
Sorry no pictures yet my phone with the pictures broke and havn't been back up north yet.
scottlathrop
29
Jun 13, 2013 06:42 PM
'66BlueBlood
21
Mar 2, 2011 02:26 PM
duallydan
Sep 22, 2009 07:09 PM
bsirvine
Jul 25, 2008 02:42 PM
gordo350
Nov 9, 2004 10:01 AM
