Gear shift selector movement??
Old Jan 9, 2013 | 02:22 PM
Matt's Dad's Avatar
Matt's Dad
Hi guys, I've noticed on my Ex that the gear shift selector has a lot of movement/freeplay - It's when I go from park to any other gear, the gear I then select, I can move the lever up and down?
I've searched on here, and read about the 2 torx screws that can come loose, but I checked and they are tight - I can't see where else is loose? I took of the lower plastic cover under the steering wheel shaft, but can't get the top cover off to look in there as I don't know how to get the plastic ignition cap off (where the key goes in)
Any help appreciated It all works ok, just doesn't feel good!
Old Jan 9, 2013 | 04:00 PM
timf150's Avatar
timf150
Here you go. Mine is loose and I picked up the parts but have not made the changes.
https://www.ford-trucks.com/forums/1...l#post11717334
Tim M
Old Jan 9, 2013 | 04:23 PM
BEARDOWN's Avatar
BEARDOWN
To take that top cover off you must remove the ignition switch. There is a ball detent under the switch that will let you remove it. The key must be in the on position.
Old Jan 9, 2013 | 06:03 PM
Matt's Dad's Avatar
Matt's Dad
Thanks guys, reps sent will see how I get on!
Old Jan 9, 2013 | 11:15 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
My old '02 Excursion was like that too. I checked the few things I read could be loose, but they were all tight. I just dealt with it until I sold it, because it never caused a problem. I like me some factory original tightness now though!
Old Jan 10, 2013 | 07:01 AM
Apocalypse's Avatar
Apocalypse
Why must it be so difficult?!?
Old Jan 10, 2013 | 08:49 AM
FordGuy100's Avatar
FordGuy100
Mine does that too. To add insult to injury, one day I put it in park and heard something...and now the needle indicator in the dash is stuck on "Park"...broke the cable I think. That sucks, now its either count from park to get to whatever gear, or watch the CTS.
F-ReV
Nov 24, 2016 08:20 AM
Colorado Jones
Aug 20, 2013 05:57 AM
twillfish
Jul 15, 2009 10:14 AM
