code 1212, 1211.
Old Jan 9, 2013 | 02:14 PM
f1501987's Avatar
f1501987
code 1212, 1211.
I got these two codes, anyone know what causes it? or how it can be fixed. its a 1996 f350. auto its got a 120 idm in it.
Old Jan 9, 2013 | 02:29 PM
DIYMechanic's Avatar
DIYMechanic
From the tech/mod sticky:
https://www.ford-trucks.com/forums/9...ble-codes.html
* P1211 ICP Not Controllable - Pressure Abow/Below Desired
* P1212 ICP Voltage Not at Expected Level
Try pulling the superchip out of it and see if you still set the codes.
Old Jan 9, 2013 | 02:32 PM
f1501987's Avatar
f1501987
I know what they mean my code reader tells me. But it just died this morning. Starting up with a lope. Then levels out.
Old Jan 9, 2013 | 02:39 PM
DIYMechanic
Pull the Superchip and try it again. If that's not the issue, then unplug the ICP and see if there is oil in the electrical connector. If there is, you need a new ICP. Aside from that, check the tin nut on the back of the IPR. It could be an IPR issue or a blown injector o-ring, but since it is doing it cold, I am guessing it is the ICP. You can unplug the ICP and try to start the truck and see if it acts any different. If it runs better with the ICP unplugged, you need a new one.
Old Jan 9, 2013 | 02:42 PM
f1501987's Avatar
f1501987
Ok weres a diagram that shows were the icp is. I really need a shop manual
Old Jan 9, 2013 | 02:44 PM
DIYMechanic
There is a picture here:
https://www.ford-trucks.com/forums/m...ors-59855.html
Old Jan 9, 2013 | 02:48 PM
DIYMechanic
Oh, and the manual:
97-15A 7.3L DI Turbo Workshop Manual
Old Jan 9, 2013 | 02:49 PM
f1501987's Avatar
f1501987
Ok thanks looking at it now. Weres the best place to buy new ones at
Old Jan 9, 2013 | 02:51 PM
f1501987's Avatar
f1501987
Ok so my check engine don't come on, with no super chip. Odd? Iv ran the chip for a while
Old Jan 9, 2013 | 06:56 PM
DIYMechanic
Was the chip loose in the PCM? If you put it back in does the CEL come back on? A loose chip could cause your issue.
Old Jan 9, 2013 | 07:07 PM
f1501987's Avatar
f1501987
Its a plug and play super Chip
Old Jan 9, 2013 | 07:14 PM
DIYMechanic
Does it plug into the PCM or the OBD II port?
Old Jan 9, 2013 | 07:16 PM
f1501987's Avatar
f1501987
Obd port its only got 2 settings
Old Jan 9, 2013 | 07:17 PM
DIYMechanic
Does the problem return if you use the chip again? And this is happening at idle?
f1501987's Avatar
f1501987
I ain't put it back on yet
