1978 - 1996 Big Bronco
Please help back window stuckdown
Old May 27, 2003 | 12:25 PM
Cameo's Avatar
Cameo
Im afirst time user at posting! I always read postings but my backwindow is stuck down!! Motor is gone for sure!! How do I get window up!! THANKS
Old May 27, 2003 | 12:43 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
You can't be sure it is the motor until you test it. Either way, you have to open the gate, take off the access panels, and un bolt the window from the lifting arm. Then it will slide right out. Oh yeah, and the weather stripping has to come off too. Once it's out, check for power...
You can't put the window up without the guts working properly. Well, you CAN, but I just can't let a Bronco drive around with duct tape all over the place and be able to sleep at night, so you're not going to get THAT advice from me.
Just take the top off for now - you won't need the window that way!
Old May 27, 2003 | 04:08 PM
cajunbronco's Avatar
cajunbronco
Can you hear the motor running? If not there is a contact switch on the top left side of the gate.This keeps the window from opening unless the gate is shut.Check for power at the switch and at the motor.If you can hear the motor running one of the nylon sliders in the window channel may be broke or stuck.
CB
Old May 27, 2003 | 11:22 PM
Cameo's Avatar
Cameo
Ive done everything that is posted!! There is power to the motor i checked it rigt to the motor!!
Old May 27, 2003 | 11:37 PM
steve83's Avatar
steve83
Then the motor is shot, and you'll have to remove it from the regulator before you can push the window up. These pics should help.
Old Jun 1, 2003 | 06:03 PM
buckeyebronco's Avatar
buckeyebronco
WAIT
Check the switch that tells the motor if the tailgate is shut all of the way. I thought mine went out and got ****** of and slammed the gate shut and sure enough something was jammed and came free and the window worked.
Old Jun 1, 2003 | 11:43 PM
steve83's Avatar
steve83
That switch cuts power to the motor, but he said he has power there.
Old Jun 2, 2003 | 10:22 PM
Cameo's Avatar
Cameo
Hi everyone. Thank you all for your help and suggestions. I got my back window out by drilling 4 holes i my tailgate and cutting off the bolts in the window and pulling out the window and rplaceing the motor. All works great.
BriWas
May 8, 2013 08:22 AM
mfire138
Ford Truck Parts for Sale
Oct 31, 2012 10:14 AM
Phrekkle
2004 - 2008 F150
Jan 14, 2007 12:16 PM
jbrdrummer
Paint & Bodywork
Aug 9, 2003 09:44 PM
AlM
User Gallery & Picture Display
Mar 10, 2002 09:03 PM
