1978 - 1996 Big Bronco
Exaust Noise
Old Jun 1, 2003 | 05:44 PM
buckeyebronco's Avatar
buckeyebronco
Exaust Noise
I'm back after a few days away and it is starting to get warm again in Ohio and my trusty Bronco is acting up. When I accelarate my exaust sounds funny like there is a metal plate on top of the cat rattling but I don't think there are any leaks, its only 2 years old. Any Thoughts on what it could be?
Old Jun 1, 2003 | 06:22 PM
Laviathn's Avatar
Laviathn
Exaust Noise
try bouncing the bronco up and down or shaking the exaust(when cooled) with you hands, to see if you hear any noises...still might not hear it but it still might be something loose and/or rubbing
Old Jun 1, 2003 | 06:32 PM
Scooby2's Avatar
Scooby2
Exaust Noise
check out the heat shield on your cat(s)......those things will raise all sorts of noise if the screws start comming out.
Old Jun 2, 2003 | 01:23 AM
brian_06328's Avatar
brian_06328
Exaust Noise
I used a rubber mallet on mine, lightly tapping, and found a rock under the heat shield.
Brian
Old Jun 2, 2003 | 05:22 PM
buckeyebronco
Exaust Noise
It only occurs when the engine is under load. i.e in gear and accelarating. when in nuetral or park and i rev the engine it does it a little but hardly at all.
Old Jun 2, 2003 | 10:31 PM
Trucky18's Avatar
Trucky18
Exaust Noise
I had that happen to me, the top to rivits had rusted out of the cat sheild, i just bought two 1/4" nuts bolts and lock wahsers and bolted it back together, i took like 20 min to fix
dare1508
Apr 20, 2012 07:04 AM
scottddove
Mar 15, 2006 11:44 AM
muscletruck7379
Aftermarket Products
Dec 5, 2004 11:11 PM
Stampede
Ohio Chapter
Apr 20, 2004 10:32 PM
fordtrck302
Exhaust Systems
Mar 23, 2002 03:22 AM
