running boards
Old Jun 23, 2018 | 09:14 AM
wharthog's Avatar
wharthog
running boards
I just can't find a running board that works like I feel it should for my "14" F-150 super crew. I have the oval tube type now they are useless while getting out of the truck. Even my wife agrees they are too narrow or tucked under the cab too far to be useful. I have been looking for a step like I had on my Super duty, a wide flat step that runs from the front of the front door to the rear of the rear door. Even the Raptor steps are too narrow. I just saw a pair at the grocery store, got out and checked them out up close. They are a little better than the tube I have but only in the front door area. I even asked at the aftermarket place near me, the guy could only show me more tube steps.
Help! I can see the seat will be ruined in short order from sliding off while getting out of the truck.
Old Jun 23, 2018 | 09:43 AM
ubereal2's Avatar
ubereal2
Here's what I have on my 2013 F150 Super Crew. They're aftermarket, and fit like a glove, you'll see in the pictures that they actually go to the front of the rear wheel well. And unless your off road and really have that frame twisting (and I don't) that should never be an issue.
Mine have been on the truck for a couple of years, and have had zero issues.
I've included a link from my purchase if you want to see more.
Amazon Amazon
Unk Bob
Front side view
Left side view
Top View
Old Jun 23, 2018 | 11:18 AM
rbentnail's Avatar
rbentnail
Do an Amazon search for 'ford truck nerf bars'. The ones I put on an '01 Scab were very nice width & length. Even my petite wife could manage with them.
Old Jun 23, 2018 | 11:53 AM
jdunk54nl's Avatar
jdunk54nl
Amp power steps. They are lower than other styles, they extend farther away from the door, and are out of the way when you are driving. They are expensive but nearly everyone that I know that has them loves them and won't go back to other styles.
I have the ford factory version and won't ever have a truck that doesn't have them again.
Old Jun 25, 2018 | 10:16 AM
King-bRanch's Avatar
King-bRanch
x2 on the AMP Research Power Boards
Old Jun 25, 2018 | 07:43 PM
wharthog's Avatar
wharthog
OK, I hate to say it but the fold up ones look like they might be what I have to get. Man, I didn't want to spend that kind of money. King-bRanch, can you post a top view pic and or a side view with the steps out?
Old Jun 26, 2018 | 11:28 AM
calvynandhobbs's Avatar
calvynandhobbs
I see you're in Michigan. Are you anywhere near Kalamazoo? You could stop into JCR Offroad and they could probably build whatever you want. They did some rocksliders/steps for my Bronco years ago.
Old Jun 26, 2018 | 02:38 PM
Lone Wolff's Avatar
Lone Wolff
These are what came OEM on my 2010 Lariat SCREW. Flat and about 6" wide.
Old Jun 26, 2018 | 08:13 PM
zxwut?'s Avatar
zxwut?
I've had the stainless steel, powdercoated Aries steps on here since the first week or so of owning this truck, so ~75,000 miles with little noticeable wear. I like the them because they don't ruin my ground clearance because they go further out than down and as a side benefit, they make the ultimate in parking lot door ding prevention! I can't count the times I got to have a good chuckle as someone bounced their door off my steps instead of my expensive sheet metal. Leaves a nice dent in their door and nothing on mine
Old Jun 27, 2018 | 09:05 AM
wharthog's Avatar
wharthog
Quick question for zxwut. How wide is the bracket that hold the tube up? With just two arms to hold up the tube it would make me think they would flex a bit with my crippled fat **** stepping up on them. Now at 230# after surgery, what I dont need is another fall. I do like how far they are from the door sill.
Old Jun 27, 2018 | 07:56 PM
zxwut?'s Avatar
zxwut?
Aries (Curt) lists them with a 250lb weight limit. I've had heavier people than that in and out on them routinely, but that's what they advertise. I work with some large people.
Old Jul 6, 2018 | 01:38 PM
ThirdsACharm's Avatar
ThirdsACharm
I had OEM ones. After 7 yrs the paint started blistering. After thinking about it, I thought it would be better in the long run to replace them rather then sand/prime/paint.
I thought the OEM ones were nice but they were slippering when we or detailed.
I really wanted the AMP steps but I just couldnt justify spending that much, especially when my neighbor with a newer F150 with them gripes about how winter caused some issues with his OEM power ones.
I went with Luverne omega 2, which I thought were reasonably priced, looked pretty good, and the grips are really solid. I'll have to add pics later, I dont have any right now.
Old Jul 8, 2018 | 08:50 AM
mueckster's Avatar
mueckster
Check out the many options offered here. https://runningboardwarehouse.com/sh...supercrew.html I have the Ionic Factory Style Running Boards. Much better footing when entering and exiting the cab; especially when you have to open the door slightly in tight places.
Old Jul 8, 2018 | 10:12 AM
King-bRanch
Sorry for the delay, but I've been too busy lately to be on here....
Here's a pic as requested, the boards are perfectly flat & over 6 inches wide.
Old Jul 9, 2018 | 07:57 AM
Olytlr's Avatar
Olytlr
If you can afford the amp steps that is the way to go. I personally love my Raptor running boards. They are nice and wide, have tons of grip and tuck up tight against the body.
