6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
BEDPLATE
Old Jan 8, 2013 | 02:55 PM
magum350's Avatar
magum350
BEDPLATE
CAN SOMEONE TELL ME WHAT IS CAB OFF BEDPLATE,WHAT IS THE PROBLEM AND WHAT TO LOOK FOR,I Have a 08,f350 almost 35k,tuned and deleted.
Old Jan 8, 2013 | 05:49 PM
senix's Avatar
senix
you have to take the cab off if you have a leak and it is the bed plate.
Basically the bed plate is a design from navistar that split the bottom end of the motor into a couple of sections.
See the attached.
File Type: pdf
Old Jan 9, 2013 | 08:06 AM
magum350's Avatar
magum350
thanks,so I have to keep checking oil pan for leaks,engine comes out I guess,what if any warrenties are on that if yuor over the years,or does it matter and dailer has to fix
Old Jan 9, 2013 | 10:27 AM
senix's Avatar
senix
You really don't have to check it unless you notice it. In over 76K miles mine does not leak.
Old Jan 9, 2013 | 10:44 AM
magum350's Avatar
magum350
thanks for the info I change oil every 5k so I'll check it on every change
joejackF250
Jan 23, 2019 07:42 AM
MIKE1646
Feb 15, 2009 07:35 PM
Staeve
Jul 13, 2008 08:35 PM
n6nfg
May 22, 2007 12:06 AM
Reave1
Apr 17, 2006 12:33 PM
