Oil Leak found
Old Apr 17, 2006 | 07:25 AM
Reave1's Avatar
Reave1
Oil Leak found
The dealer found my oil leak and they are telling me it is coming from the plate the is located bewteen the oil pan and the block. They are saying that the motor has to come out to fix it. Is this true? The truck has 10,000 miles on it and I am scared that the motor is being removed. How many other problems is this going to start. Has anyone else had this problem? If so let me know what is right.
Old Apr 17, 2006 | 11:26 AM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The plate you refer to is called the bed plate. Unfortunately, it's not uncommon to have a leak at this location. If I'm not mistaken, it will require the removal of the oil pan and then bed plate to repair. Unfortunately, to get the oil pan off, the engine has to come out. If it makes you feel more comfortable, your tech has probably done this more than once and is probably experienced at the task. However, you might want to ask how many times they've done this particular job. If it's a good shop, it won't be a problem.
Old Apr 17, 2006 | 12:33 PM
texcan's Avatar
texcan
Powerstroke_wannabe is right. But to top it all off the will remove the cab from the chassie to pull the motor. I don't like the sounds of that, more problem down the road as far as sceaks and rattles.
