Help in choice for rad
Old Jan 9, 2013 | 06:06 PM
V10man's Avatar
V10man
So the aluminum ones have better cooling than the brass/copper radiators?
Old Jan 9, 2013 | 06:46 PM
bucks77ford's Avatar
bucks77ford
Not necessarily. The tubes in the aluminum are wider than copper so the theory is that aluminum dissipates heat faster, plus I think the wider tubes in the aluminum ones create a difference that a 2 row aluminum is as good as a 3 row copper and so forth so there is quite a bit of money saving that could be there. Bang for buck is where the aluminum radiators (depending on brand) can be better than copper which is expensive. The huge 4 row copper radiators are about the best you can get for these trucks, but are over $450 I believe. A cheaper 3 row aluminum can be had for under $300. You are going to hear the argument for both types and which is better.
Old Jan 9, 2013 | 06:58 PM
V10man's Avatar
V10man
I hear ya. I found a 4 core alum but it has plastic tanks, for $260.
Old Jan 10, 2013 | 05:31 PM
77460ford's Avatar
77460ford
I decided on a replacement rad; first though I want to thank everyone for contributing your thoughts and suggestions as it really was appreciated. I'm going to order the Super Cooler rad from JBG (#20604), I still like cooper rads and that one should do the job.
Old Jan 10, 2013 | 06:05 PM
bucks77ford
I don't think you'll have a problem with that radiator. I'm also assuming you have a front flange mount core support as there were some rear flange mount in 77. At least a 77 parts truck had a rear flange mount core support that I used and it sucks because most aftermarket radiators are front flange mount.
Old Jan 10, 2013 | 06:25 PM
77460ford's Avatar
77460ford
Oh sure, scare the crap out of me! Since the truck is in storage I had to search through pics to make sure which it was, front flange...whew
Old Jan 10, 2013 | 07:03 PM
bucks77ford
Good.......because when I first ordered a radiator for mine, I went to install it and had the wrong one. But, I made it work anyway.
Old Jan 12, 2013 | 12:34 PM
V10man's Avatar
V10man
Now I am worried about which "flange" type I have. My current rad has a flange kinda in the middle. I can see two flanges with holes on the outter edges, fan shroud is mounted on one of them. Then between the 2 there is the bracket that mounts the rad to the header. Which flange type is this? see red arrow...
Old Jan 12, 2013 | 12:59 PM
bucks77ford
That core support is made for a rear flange mount radiator. This is what a core support looks like for a front flange mount. It doesn't have the side mount supports so the radiator mounts to the front of the support.
i-w
Jun 15, 2019 08:47 AM
DRVMUSTANGS
Feb 10, 2017 01:22 PM
1976 Highboy Ranger
Sep 28, 2014 08:01 PM
Blown 331
13
Mar 25, 2012 09:14 PM
DuckRyder
Oct 18, 2003 03:45 AM
