Well since my truck has a cage bed and basicly a set of trailor lights the right turn signal doesnt work when the headlights are on.
Now heres the tricky part that I cant figure out.. If you unplug the pig tail that plugs into the rear right light and use a test light the test light will flash like it should (as if it was the actual bulb for the light). Now these lights are only one bulb lights but the left side works fine. So any help or ideas would be great!
I was thinking it was a ground problem as well. I used to be really good at electrical grimlins but 3 years in the military with hardly time to work on anything will remove that knowledge quickly
