Starter Replacement
Old Jan 7, 2013 | 09:03 AM
GeneLaw1's Avatar
GeneLaw1
Starter Replacement
I believe it is coming time for me to replace my starter. Every blue moon, I will hear a grind when I turn the key. When I turn the key again, truck fires up with no problem.
How hard is it to replace the starter on the 6.0?
Old Jan 7, 2013 | 09:50 AM
daddykitty's Avatar
daddykitty
i looked at mine yesterday thinking i would drop it to install a fumoto valve....i passed
Old Jan 7, 2013 | 10:05 AM
GeneLaw1's Avatar
GeneLaw1
I take that to mean it's pretty tough??
Old Jan 7, 2013 | 10:31 AM
Frankenbiker's Avatar
Frankenbiker
Before you go that far, check your cables, especially the grounds.
Cable corrosion is a much bigger issue than a failed starter, "usually."
-blaine
Old Jan 7, 2013 | 01:13 PM
npccpartsman's Avatar
npccpartsman
It's not that hard just be careful taking the cables off of the solenoid. It's easy to break the connection and ruin the core.
FWIW--I went with a NAPA reman and it's been a dream. It cranks MUCH faster than the stock starter and the solenoid cable connections are reinforced.
Old Jan 7, 2013 | 04:51 PM
greentree ford's Avatar
greentree ford
crawl under truck and take a look several starters on 6.0 have just come lose or worse even fallen out
Old Jan 7, 2013 | 06:12 PM
snorindad's Avatar
snorindad
I pulled my starter and installed fumoto valves for block drains and had it running in less than an hour. Just use a long extension for the top inside bolt. Not a bad job at all.
Old Jan 7, 2013 | 08:19 PM
Roasted7's Avatar
Roasted7
There's just one PITA bolt on the top side that you can't see and you'll need a long extension. Otherwise it's easy. And yes, the solenoid screw is VERY delicate. Broke mine.
Old Jan 7, 2013 | 08:21 PM
Sullid01's Avatar
Sullid01
There is a top bolt that is impossible to see from below. It is a 13mm. I took off the front passenger wheel and wheel liner - then it is very easy. It is staring right at you. That may be the best way to get a proper look at the cables before you buy a starter that you may not need. Don't forget to disconnect the batteries before messing with it - it makes cool sparks!
obscurity
Jun 1, 2017 05:06 PM
anied52
18
Jul 22, 2016 04:56 PM
Gates
Apr 19, 2003 05:55 PM
seymour
Nov 29, 2002 10:15 PM
Monsoon
1978 - 1996 Big Bronco
Mar 20, 2000 01:12 PM
