I will be replacing my turbo(bad oil seal) this Thursday. I have read somewhere that there is an updated Turbo drain tube.... ??not really sure what it is. If anyone has any info or part #'s on anything else that I might need to complete the job, the help would be much appreciated!
I'm at work so no part # access right now but IMHO it's a waste of money for the drain tube. I'd be more worried about the supply line with the flex section that can pinch/collapse internally.
Any part #'s for supply line gasket or drain tube o-ring? I would imagine these parts are readily available from the local Ford dealer, but we live in a pretty small rural area, and I just want to be prepared.
Ford and internationl part #'s. Price the parts at both as the drain and feed tubes are cheaper at alternate places.
