Fuel pick up issue
Old Jan 7, 2013 | 09:35 PM
dn29626's Avatar
dn29626
3/8 compression fitting & short 3/8 metal line for pick-up (replaced plastic boot)
5/16 compression fitting & 5/16 metal line for return.
You will use less than 6 inches of 3/8 line for the pick-up and i suggest about 12 inches of 5/16 for the return.
Originally Posted by F350long
So......just the pipe like in the picture?...
Yes. That is in my tank.
Originally Posted by cutlass
1)...the picture is too small for me to see the end of your fuel pick-up tube. Did you flare the end of that tube...
2)...Also, how long did you end up extending the fuel pick-up tube from the circular plate on the top of the tank?...
3)...What distance from the bottom of the tank did that leave the end of the pick-up tube?...
Thanks,
Drake
1) The lines are metal brake lines so they have the flare already (you cut off one end).
2) To get the distance, lay a straight edge across the opening of the tank, going through the opening-touch the bottom using a tape measure or yard stick, take note of the measurement to the straight edge (similar to that shown on Guzzles site), subtract about 1/4 inch. You have your number.
3) About 1/4 inch.
Old Jan 7, 2013 | 09:45 PM
gengine's Avatar
gengine
The easiest way to get at the top of the fuel tank, is to raise the bed. I remove the bolts on the passenger side, then put two of them in about 1/2", then remove the bolts on the drivers side, disconnect filler tube, and in some cases, unplug the wiring harness from frame to bed, then lift and block really well. I can't imagine it would feel good if the bed came down. This way, if your tank is full, you don't have to have a strong son to help ya! Sorry BWST, had to take a jab...welcome to FTE!
Old Jan 7, 2013 | 09:46 PM
cutlass's Avatar
cutlass
3) About 1/4 inch.
When you measured distance from top to bottom of tank, did the tank have any fuel in it at all as it lay across any support on both ends allow the natural 'bow' in the bottom of the tank that would occur when it is full of fuel?
Also, does not having a fuel pick-up foot cause any issues with air intrusion when the tank is low on fuel?
Thanks,
Drake
Old Jan 7, 2013 | 09:56 PM
Crewcab Turbo's Avatar
Crewcab Turbo
The easiest way is to lift the bed like this. My tank was 3/4 full at the time.
Old Jan 7, 2013 | 10:08 PM
dn29626's Avatar
dn29626
1)...When you measured distance from top to bottom of tank, did the tank have any fuel in it at all as it lay across any support on both ends allow the natural 'bow' in the bottom of the tank that would occur when it is full of fuel?
2)...Also, does not having a fuel pick-up foot cause any issues with air intrusion when the tank is low on fuel?
Thanks,
Drake
1) I was so concerned about getting it right that my tank was almost empty, but i attempted to flex the tank a number of times, very little movement. I also took note of the locations of the holding straps, very little room to bow or bulge.
If you are concerned about getting too close to the bottom, bend an angle into the 3/8 tube to lay against or near the bottom and not straight down.
2) Never had an air intrusion issue with this in my tank.
I have purposely driven my truck 75 miles after the low fuel light came on. I think i am OK.
Old Jan 7, 2013 | 10:24 PM
cutlass's Avatar
cutlass
1) I was so concerned about getting it right that my tank was almost empty, but i attempted to flexed the tank a number of times, very little movement. I also took note of the locations of the holding straps, very little room to bow or bulge.
Thanks David! I tried to rep you but was shot down.
What is the deal? I have been rejected the past 5 times I've tried to rep someone. What does it take to rep someone? Can someone explain to me how this works specifically?
Drake
Old Jan 7, 2013 | 11:33 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Here's my tip on the FRX install.
Instead of removing the fuel bowl bolts to get some room to maneuver the return line remove the single bolt that holds the supply and return line bracket to the block. It's right next to the battery ground cable. You get just the play you need. That fuel bowl bolt close to the EBPS bracket is a PITA.
Old Jan 8, 2013 | 05:12 AM
dn29626's Avatar
dn29626
...Thanks David! I tried to rep you but was shot down.
Drake
I appreciate you trying. I do not know the rep rules.
I have not been shot down. I know to click on the red heart, another window opens, type your reason for the rep and click the accept tab.
I expect that is what you did.
Grinder Man
Oct 10, 2014 09:35 AM
93f25073
35
May 23, 2013 04:04 AM
SPEC
Dec 2, 2007 07:55 PM
d60d70
Modular V10 (6.8l)
Jul 30, 2007 10:36 AM
