Electronics delete on feedback carb?
Old Jan 11, 2013 | 04:54 AM
Ken Blythen's Avatar
Ken Blythen
Bill,
Regarding my feedback carb, are we correct that -
1. The computer being completely disconnected from the carb, would give a full-rich condition?
2. The computer having a connection to the carb, but none to the ignition (via the crank sensor), would give a full-lean condition, as with 82F100SWB's truck?
Old Jan 11, 2013 | 06:36 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Ken, I really can't tell the information I have on the 2150 FBC is extremely vague. I suspect the delete kit may be the altitude compensator that was used on non-feedback high altitude vehicles. All I can find on your system is that it is a duty-cycle solenoid that controls additional air into the carburetor. I would suspect that if everything except the DS-III crank sensor was working the O2 sensor, MAP and Baro sensors, TPS are there it may work. Somewhere I have a 1982 Lincoln shop manual set that covers the EEC-III system. I am not at home in Newport News at present, I am at my retirement home in Exmore, VA. When I get home I will see if it sheds any light on the subject.
You may be able to feel the solenoid pulse when the engine is running, if so it is working, if not, it appears to be 12V powered, so applying 12V across it would probably cause one of the 2 conditions. I am leaning toward: no signal = rich, full power = lean from what I remember on these, I do have a 4.9L FBC, if the mixture solenoid is still attached I can do some checking.
Old Jan 11, 2013 | 08:55 AM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Ken Blythen
Bill,
I doubt that #2, above, is accurate. I would think the limp-home mode would put the carb in full rich rather than full lean condition since engines run better/longer rich than lean. And, what Bill said about no power being full rich would tend to support that.
Old Jan 11, 2013 | 12:27 PM
Ken Blythen
OK - Thanks Bill & Gary.
I did find posts of JimsRebel that relate. Maybe this is the thread you meant, Gary?
https://www.ford-trucks.com/forums/1...-feedback.html
His feedback carb was disconnected from the computer & he ran it for three months experimenting with a manually operated 'full lean' switch, that he used as much as possible (monitored off the O2 sensor)..........vs no electrical connection at all (full rich).
He didn't get any measurable difference in mpg, so has used the carb since on full rich.
Old Jan 11, 2013 | 12:36 PM
Gary Lewis's Avatar
Gary Lewis
That's the thread I was thinking of, but couldn't find. Odd that he couldn't see any difference in MPG. Suggests either the carb wasn't working correctly or the changes are so minimal that they don't show up in the overall MPG.
Old Jan 11, 2013 | 01:26 PM
Ken Blythen
Yeah, I guess it is still a carb, not EFI.
By that, I mean a non-feedback carb is jetted to operate satisfactorily over a range of conditions........so maybe there's only a pretty narrow range of variation that the feedback system provides, alongside the conventional jets.
Old Jan 11, 2013 | 01:53 PM
Gary Lewis's Avatar
Gary Lewis
Bill can probably confirm, but I've heard that changing the float level can have a minor effect on AFR. And it seems to me that changing the pressure in the bowl is essentially the same as changing the float level. So, it follows that the effect would be minor.
Old Jan 11, 2013 | 02:32 PM
85lebaront2
Gary, the biggest thing a float level change does is effect the fuel pickup on the main circuit. Higher gives a quicker tip in, lower gives a slower tip in. The system Ford used on their feedback carbs other than the infamous VV is an auxiliary air bleed system on both the main and idle circuits.
Old Jan 11, 2013 | 03:02 PM
Gary Lewis's Avatar
Gary Lewis
The solenoid controls an auxiliary air bleed rather than the bowl pressure?
Old Jan 11, 2013 | 03:06 PM
85lebaront2
Yes, the VV controls bowl pressure for mixture control.
Old Jan 11, 2013 | 03:07 PM
Gary Lewis's Avatar
Gary Lewis
Ok, got it. Thanks.
RVbud
Apr 30, 2010 11:39 AM
Paul.Harrah
1978 - 1996 Big Bronco
Mar 6, 2008 04:26 PM
Jag Red 54
20
Jul 19, 2005 11:48 AM
ck85abc
Nov 24, 2003 01:57 PM
Njbmx
Mar 30, 2003 06:29 PM
