cooked spark plug wires
Old Apr 11, 2010 | 10:47 AM
RVbud's Avatar
RVbud
Question cooked spark plug wires
I have a 1989 class A RV with a 460 engine. I have gone thru three sets of spark plug wires in the past 2 years, due to extreme heat melting the wires at the spark plug ends. I had the manifold gaskets removed because the mechanic told me that this engine was not designed to have gaskets. The engine is noisey and it backfires when it is cold, but once it warms up, it quiets down and runs smoothly.
Are there supposed to be manifold gaskets and perhaps heat shields on these engines to protect the spark plug wires?
also, I am told that this engine has a Holley 4 barrel carb set with Calif. emissions settings. Could this have anything to do with the backfiring?
Old Apr 11, 2010 | 12:10 PM
Bear 45/70's Avatar
Bear 45/70
Your mechanic is an idiot. Yes the 460 came from the factory without gaskets, but unless you pull the heads and level cut the exhaust face of the heads and the exhaust manifolds, they are gonna leak. Always use gaskets with any rebuild. Oh and find another mechanic.
Old Apr 11, 2010 | 03:57 PM
RVbud's Avatar
RVbud
Thanks Bear. Do you know anything about the california holley carb? I think this is causing the backfire. Or, I have read (here) about Crabby's timing problems. Might that be causing backfire?
Old Apr 11, 2010 | 05:36 PM
Bear 45/70's Avatar
Bear 45/70
I have a 1984 heavy duty F250 (a light 1 ton) with a 460 and the Holley carb, or I should say "had". The Holley 4180 4 barrel carb is an emissions carb and I tossed it in my carb parts bin and replaced it with a Holley 1850, 4 barrel non-emissions carb that I massaged. Instant 1.5 mpg improvement with across the board throttle response improvement. The 4180 runs too lean normally and if anything goes wrong with it it gets too lean. My theory is to replace the 4180 because all the adjustments are limited and the idle mixture screw are air adjustments and not fuel adjustments, Hence turning them out makes you leaner, not richer. Backfires are almost always caused by too lean, ignition timing way off or valve timing wrong (bad timing chain).
Old Apr 14, 2010 | 08:44 AM
Bern_F150_4x4's Avatar
Bern_F150_4x4
RVBud, your truck should have heat shields that cover the manifolds to prevent the plug wire fry that your experiencing. My heat shields are still intact, I can snap a pic if you would like.
In your truck those manifolds will glow cherry red anytime you are on the throttle for an extended period of time i.e. hill climb. You can purchase high temperature thermal sleeves to place on your plug wires to help protect them. I’m not sure if the OEM shields are still available from Ford, this sounds like a job for numberdummy. I would consider getting the shields if you can find um...
Old Apr 14, 2010 | 09:18 PM
Bern_F150_4x4
Here's a pic of the Left side heat shield on my '86. You will notice it serves a dual purpose as a manifold gasket and heat shield. The Right side (no pic) has the same shield and also has the heat riser over the majority of the manifold. Also note the rubber hose over the plug wire, I suppose the PO had issues with cooking wires on my truck too!
Old Apr 14, 2010 | 10:13 PM
Bear 45/70's Avatar
Bear 45/70
The only time those shields are worth the effort to keep is if you have an exhaust leak.
Old Apr 30, 2010 | 11:39 AM
rotun's Avatar
rotun
Reads ***** rules!
I had the same problem on my 429, replaced the plug wires with a set of MSD customs. Used the thinner plug ends, be sure nothing is touching the exh. manifolds. I found the oem were too thick which placed them too close and the heat destroyed them. The thinner ends, longer and can be shaped any direction, are not as close now.
camsx2
1997 - 2003 F150
Dec 21, 2020 09:26 AM
Felix Perez
Dec 10, 2016 10:21 AM
farmboy11102
Jul 19, 2016 08:42 AM
Wild Weasel
Sep 27, 2011 12:37 PM
bigwin56f100
Apr 24, 2006 09:54 AM
