1978 - 1996 Big Bronco
Spark Plug ?
Old Mar 6, 2008 | 10:58 AM
Paul.Harrah's Avatar
Paul.Harrah
Spark Plug ?
I have a 1984 with a 351W, It was a california truck at one time and had that computer controled carb and dizzy, well I took out the computer and replaced the carb with a holly 4412 and a Hei dizzy my question is should I run a hotter plug now since I am running a HEI? Or should I stick with the stock ones?
Old Mar 6, 2008 | 01:39 PM
Kemicalburns's Avatar
Kemicalburns
stick with stock and see how it runs
Old Mar 6, 2008 | 02:33 PM
alxsnmr's Avatar
alxsnmr
2nd that, 'read' the plugs later to figure out if you need to change the heat range, but most likely you will not need to change the plug to a different type.
Old Mar 6, 2008 | 04:02 PM
Red Ford Truck's Avatar
Red Ford Truck
With the hotter HEI ignition .....................
You may just want to open the gap up on your current plugs which should give you a little better fuel economy and performance to boot.
Rick.
Old Mar 6, 2008 | 04:06 PM
Paul.Harrah
What do you think I should open them up to ?
Old Mar 6, 2008 | 04:14 PM
Red Ford Truck
What do you have them gapped at now?
Whats the factory spec for this engine?
Rick.
Old Mar 6, 2008 | 04:26 PM
Paul.Harrah
I am not sure right now I will check after work.
