speedo correction/tire size
Old Jan 6, 2013 | 06:34 PM
eckart's Avatar
eckart
My sons 1998 ranger 4.0 auto 4x4 has stock 265 75 15(10.5 x 31) tires and I want to put 235 75 15 winters on it when he gets his license in Febuary. How do I recalibrate the speedo?
Old Jan 6, 2013 | 07:04 PM
johnday's Avatar
johnday
I could be totally wrong, but I think the 235/75/15 are the stock tires. If so, you shouldn't need to do anything unless someone changed out the speedo gear in the past.
Take it out on the freeway at 60mph indicated, it should take one minute between milemarkers, or very close, with the 235's that is.
OOps, I just saw you're in BC, so, at 100kph, it should be around 37 seconds per klm marker. Or pretty close. If my math is correct.
Old Jan 6, 2013 | 07:15 PM
Hank85713's Avatar
Hank85713
you need to run for about 10 miles holding 60 mph and have a stop watch to cover the time it takes to go that far. There are some sites on the net that will do the math if you have the time and distance covered to tell ya what you were doing. Another way is to use a dash mounted GPS and correlate the 2, gps will be the most accurate.
Old Jan 6, 2013 | 07:30 PM
grandmas77f150's Avatar
grandmas77f150
Some trucks came with 265/75's stock, but not in 98.
Just use a GPS to find out the difference, it won't be much.
Old Jan 6, 2013 | 10:46 PM
reddog99's Avatar
reddog99
Here are a couple of tire size comparators. There are undoubtedly more, but these are an easy start:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Tire size calculator
Old Jan 7, 2013 | 07:47 PM
eckart's Avatar
eckart
its a 1998 and the stock size listed on the truck is 265 75 15
Old Jan 7, 2013 | 08:10 PM
grandmas77f150
That site lists a 215/75/15 as OEM
Superduty.pride
32
Oct 14, 2011 07:11 PM
woodtickca
2004 - 2008 F150
Apr 28, 2008 03:19 PM
tholt34
Apr 30, 2007 12:29 AM
DaveK88
Aug 28, 2006 07:58 PM
Joe98684
Jun 23, 2005 03:38 PM
