A GPS showed my speedometer to be off 2 MPH slow at 75 MPH (indicated) with 285/75's. However, the speedometer was 1 MPH fast with the stock size of 265/75's. I think that you'll find a lot of people on this forum that have actually "fixed" their speedometers by going to the larger tire. Unfortunately, there are VERY RELAXED guidelines on actual speedometer accuracy set by the feds. Besides not every 285/75-16 is 285 mm across and 32.?? inches tall. Every brand is just a little bit different.
When I had 285's on my truck (3.73 gears) GPS showed my speedo to be reading 3mph slower than actual speed. 70MPH on the speedo = actual speed of 73MPH per GPS.
There's another technique for checking speedometer accuracy for those of us who do not have the convenience of a GPS... it's called Cruise control plus mile markers plus a stopwatch. Works great.
My '02 F250, with stock 265/65/R16 Michelin LTX M/S's, is 1.5-2.0 mph slower tahn the speedometer says. I'm going to increase to 285/70/R16's, which should be almost the exact correction and will look better to boot (depending on tire manufacturer, of course).
Mine is 3kmph slower. When I show 97km I am actually going 100km. Sorry for the Km but I am Canadian.
It's ok you can't help it, you get a pass for driving a blue oval . I run 285's and with the gps it is dead on a 60 as well, but at 70 the spedo is 1 or 2 mph slow.
Running 285s pretty much put my speedo right on the money when comparing to the GPS. Seems if I set it at 75 now I don't get passed nearly as much as I was before.
