oil pumps
Old May 27, 2003 | 01:14 AM
metallicafan's Avatar
metallicafan
oil pumps
hi everyone, i gotta pick up an oil pump for the 351w im building, whats the deal with stock replacment, high volume, and high pressure? what would you recomend?
Old May 27, 2003 | 02:23 PM
goofin's Avatar
goofin
oil pumps
melling, sealed power both make a combination high vol/press oil pump. also get a arp drive rod, its cheap insurance.
Old May 27, 2003 | 10:20 PM
Adam Culpepper's Avatar
Adam Culpepper
oil pumps
for any stock crank/stock block application, stick with the standard volume pump.
high volume and high pressure pumps cause excess wear on the cam gear, and can suck the stock pan dry if the rpms stay too high for too long. windsors have EXCELLENT oiling from the factory. there is no need to do it. youll just lose hp. your internals wont be any slicker for it. save the high volume pumps for the chevies.
Myfreeford
Mar 12, 2012 11:55 PM
mcallister
Mar 23, 2008 09:33 AM
aocabrown
20
Jan 4, 2008 11:06 AM
BCS_tx_dieselman
Mar 10, 2004 03:06 PM
Jerry in Indiana
Oil & Lubrication
Oct 16, 2003 04:19 PM
