Alternator Wiring Trouble
Old Jan 5, 2013 | 12:24 PM
BullyBlue85's Avatar
BullyBlue85
Howdy guys,
I've got a 1985 F150 with the inline six 300.
Recently I've been having some electrical issues. With the engine running, if I use a turn signal, or my high beams, or use any accessory whatsoever, my radio shuts off and then turns back on. My headlights and dashlights seem to be dimmer all the time also. Now today my truck won't start. I tested the battery and it still has 12.4 V. I replaced both the alternator and the battery a year ago. I know the PO messed with the charging system wiring so I took a look and there is a melted wire going from the alternator to the starter solenoid, but the fusible link appears to be intact and the melted wire tested positive for continuity. I am hoping that is the problem because like most people, auto electrical systems really frustrate me. The connection is labeled "B" on the alternator, and it is a black and orange wire. The wire splits and goes to the starter, volt regulator and I believe the choke. There appears to be another fusible link where the wire splits labeled "N", and unfortunately the PO spliced the lead to the choke very close to that link. I'd love to find the whole alternator wiring setup and replace it as a whole, as it looks like the PO messed with it a fair amount.
Does anyone know where I can find that wiring? And what is fusible link N and can I buy an aftermarket replacement in the event I can't find the alternator wiring as a whole. Also I do not have a wire running to the "Ground" post of the alternator, as there was not one when I got the truck. Any thoughts on that?
Any help would be greatly appreciated, as I'm trying to sort this wiring mess out today and have my truck back on the road asap since it is my daily driver. I know there is a a lot to read here, and if I can give any further information please let me know.
You guys are the best,
Matt
Old Jan 5, 2013 | 02:19 PM
BullyBlue85
Also the link labeled "N" also has an "11" on the back. It doesn't look like other fusible links and so now I'm thinking it might be a resistor.
Old Jan 5, 2013 | 04:38 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Matt, it sounds like the crack head design on Ford's wiring in these years bit you. I assume you have the infamous 2G alternator, the one with two plugs, one having two large wires and one small, the other having either 2 or 3 small wires. B is alternator output, fusible link "N" is supposed to be red. You don't say whether you have an ammeter or not, it makes a difference. The ammeter system is worse that the idiot light system.
I have access to the wiring for either style and hopefully can scan and post it for you.
Old Jan 9, 2013 | 06:17 AM
85lebaront2
Matt, I posted the 1985 alternator diagrams on my website, downloads link is on left side.
Aaron Ellsworth
Jul 26, 2015 10:47 PM
Stuckinmud
Electrical Systems/Wiring
Sep 10, 2008 10:05 PM
sdetweil
Jun 13, 2008 09:10 PM
pootscratch89
Feb 23, 2006 09:35 AM
LonnieD
Jul 16, 2004 10:35 PM
