Sponsored by: Auxito
Air Filter
Old May 27, 2003 | 12:20 AM
Sony's Avatar
Sony
Talking Air Filter
I've got 1100 miles on my new 2003 F-150 Supercrew, 4.6L, and it seems pretty anemic.
I've been considering putting in the K&N filter, but should I just replace the existing filter with a drop-in, or replace the whole thing.
I live in Tucson, it's over 100F already and climbing. Lot's of dust in the air as well.
Thanks,
Walker
Old May 27, 2003 | 11:44 AM
LxMan1's Avatar
LxMan1
Air Filter
I just did the K&N thing. You may get a little more if you get the kit that actually takes in air from the fenderwell and not the underhood area. The hot air under the hood is not good for making more power.
Jimmy
Old May 28, 2003 | 09:33 AM
Racerguy's Avatar
Racerguy
Air Filter
Like lxman1 said you dont want to draw air from under the hood.
If you get a K&N be prepared to clean your MAF sensor a little more often than normal. The oil from the filter seems to foul up the MAF quite easily.
Old May 28, 2003 | 06:15 PM
Bob Ayers's Avatar
Bob Ayers
Air Filter
If you live in a dusty area, stay with the paper OEM filter. It
filters much better than the K&N filter!!!
Old May 28, 2003 | 09:35 PM
Nimroder's Avatar
Nimroder
Air Filter
I beg to differ on the idea that air from under the hood is bad. Instead of buying K&N's setup I simply seperated my OEM air filter housing,unsnapped the half closest to the firewall,tossed out the connecting piece to the firewall,cut off excess of housing behind the plastic tabs that secure it to the fenderwell then reinstalled. I seem to get plenty of fresh air from around radiator etc. and most definitly gained some in the low end torque and horsepower areas.By the way I live in Louisiana where we know all about the heat and humidity.
Old May 28, 2003 | 09:45 PM
Jimmy Dean's Avatar
Jimmy Dean
Air Filter
Hey Nimroder...where at in Lousiana? I lived just south of Baton Rouge and alos out near Pierre Part and White Castle
Old May 28, 2003 | 10:06 PM
Nimroder's Avatar
Nimroder
Air Filter
West Monroe!!! Guess I'm a yankee to you huh.
Old May 28, 2003 | 10:30 PM
Jimmy Dean's Avatar
Jimmy Dean
Air Filter
YEah, my sister lives in West Monroe I go through there often, one of the major suspension companies has offices off of I-20 there huh?
Old May 28, 2003 | 10:53 PM
03f150man's Avatar
03f150man
Air Filter
heat and humidity are one thing. heavy dust condition is another. I agree with the other post. if in a dusty environment, Use paper element filters and replace them regularly.
Old May 29, 2003 | 10:20 PM
Nimroder's Avatar
Nimroder
Air Filter
03, I agree about the paper filter. I was primarily talking about the advantages that I got from the change I made to filter assembly. Sorry about the confusion.
Old May 29, 2003 | 10:59 PM
Sony's Avatar
Sony
Air Filter
How about volume? It appears the intake is only a couple of inches across - is that enough for the engine to breathe properly?
Thanks
Old May 30, 2003 | 09:12 PM
Nimroder's Avatar
Nimroder
Air Filter
Does'nt appear to be a problem. Although I am going to install an after-market hood scoop with custom,handmade (by me) ducting that will effectively funnel air directly into OEM filter housing there-by (hopefully) creating a ram-air system.
Old May 30, 2003 | 09:19 PM
Bob Ayers's Avatar
Bob Ayers
Air Filter
First, welcome to FTE!!!
Be very careful what you are trying to do. The dynamics of airflow
in the intake system are complicated. Anything you do to cause
turbulence, or uneven airflow across the MAF sensor element
will cause a "lean" condition, resulting in pinging, poor performance, etc..
tj.brewster
Arizona Chapter
Jun 2, 2009 06:43 PM
Fordman_Evs
Feb 27, 2006 02:24 PM
Paso Fino
Oct 10, 2003 04:43 AM
