Walker Downpipe
Old Feb 25, 2006 | 09:42 PM
Fordman_Evs's Avatar
Fordman_Evs
Thumbs up Walker Downpipe
Hello All,
I read through a couple of the threads here on the board and I noticed a couple members speak about a Walker downpipe. I've tried researching it but I'm still confused is this a F-150 part or is it a retro-fitted part? Please try and explain this to me. Also, would a walker downpipe w/ EFI manifold give me a reasonable mileage and power upgrade?
Cheers,
Evs
Old Feb 25, 2006 | 09:49 PM
Bdox's Avatar
Bdox
The Walker pipe you refer to fits the efi manifolds.
The manifolds and pipe will help, but not too much by themselves. It is a good first step to upgrade the I-6 breathing. Next step, without going wild, would be chevy six rocker arms which will give you a little higher valve lift without changing cams. If you have a stock one barrel, that and the intake manifold would be the next logical upgrade.
What year is your truck?
Old Feb 25, 2006 | 09:52 PM
havi's Avatar
havi
I'll have the Roast Duck
aftermarket pipe that eliminates the factory cat. conv. It allows a cat. to be installed further back as a single cat. instead of two. Or go without a cat. at all. Designed to fit 80's fords, but can fit 73-79's with minor mods.
Old Feb 25, 2006 | 11:26 PM
Fordman_Evs
It's a '96. I'm just looking for a little more mpg and power without getting too wild.
Old Feb 26, 2006 | 07:59 PM
rhetor's Avatar
rhetor
Don't expect any noticable power or milage gains with it.
I have one, and should have saved the money for headers. Its pretty cheaply made also.
Old Feb 27, 2006 | 02:17 PM
nastruk95's Avatar
nastruk95
Where can you find a walker down pipe? What chevy motor has rocker arms to help with changing the lift? I've heard of people talking of this swap, but never actually doing it because of all the machining work.
Old Feb 27, 2006 | 02:24 PM
Roushians's Avatar
Roushians
I have a 96 F-150 too, and I bought my Walker Downpipe from a local custom exhaust shop. They had it the next day for me to pickup! I still have yet to even install it, I'm too unsure about what to do with the after-cat O2 sensor, backpressure, and the bizarre air tube that plugs into the exhaust pipe between the cats.
As far as I know, backpressure isn't an issue. The bizarre air tube as far as I know supplys fresh air to the 2nd cat to help burn pollution (so one could just cut it and let it put fresh air in the atmosphere:P). The 3rd O2 sensor can be nullified using a simulator.
johnboy427
21
Nov 14, 2011 12:34 AM
blueovaldave
Aug 21, 2009 12:43 PM
dadsgreenpsd
Sep 21, 2007 09:01 AM
drive_old_ride_new
Jun 6, 2006 03:36 AM
