Need help with steering problems
Old Jan 5, 2013 | 09:26 AM
jayjjcc's Avatar
jayjjcc
The steering on my Ex isn't working like it should. At times it feels loose when cruising then feels tight when straightening back out after a turn... the wander is really bad...
My PS fluid is also turning into a muddy brown goo every 5k... I changed the PS pump this summer with a supposedly good used one...
What should I be looking at/checking for?
Old Jan 5, 2013 | 11:38 AM
wpnaes's Avatar
wpnaes
Might be time to look into a Red Head.
Until then, have you tried adjusting the steering gear?
https://www.ford-trucks.com/forums/1...g-box-buy.html
When you replaced the pump, were you able to flush out the old fluid?
Old Jan 5, 2013 | 07:51 PM
jayjjcc's Avatar
jayjjcc
Yea I got all the old fluid out and replaced it with new ATF
Old Jan 5, 2013 | 09:21 PM
wpnaes's Avatar
wpnaes
Here's the steering adjustment thread - takes a while to get through, but worth a try.
https://www.ford-trucks.com/forums/5...-steering.html
Old Jan 6, 2013 | 10:14 AM
Snowseeker's Avatar
Snowseeker
Yup, if your fluid is turning brown after flushes I bet the box is having problems. I'll also agree with changing the steering box.
cvincent
Dec 21, 2012 06:24 PM
snookerfist
Dec 9, 2006 07:17 PM
Mr Personality
Feb 15, 2005 11:29 PM
Ronin
Bronco II
Jan 19, 2004 05:49 PM
bigdmizer
Oct 22, 2003 06:36 AM
