Need help with steering problems
The steering on my Ex isn't working like it should. At times it feels loose when cruising then feels tight when straightening back out after a turn... the wander is really bad...
My PS fluid is also turning into a muddy brown goo every 5k... I changed the PS pump this summer with a supposedly good used one...
What should I be looking at/checking for?
Might be time to look into a Red Head.
Until then, have you tried adjusting the steering gear?
https://www.ford-trucks.com/forums/1...g-box-buy.html
When you replaced the pump, were you able to flush out the old fluid?
Here's the steering adjustment thread - takes a while to get through, but worth a try.
https://www.ford-trucks.com/forums/5...-steering.html
cvincent
Dec 21, 2012 06:24 PM
Mr Personality
Feb 15, 2005 11:29 PM
