Sponsored by: Real Truck
Steering has loosened up
Old Oct 21, 2003 | 07:46 AM
bigdmizer's Avatar
bigdmizer
I have a 2000 F350 DRW V-10. The steering on it has loosened up considerably over the past couple of weeks. I can turn the wheel a few inches in either direction without effecting the trucks track. I have also noticed that my power steering pump is a little noiser than before. I only have 48k miles on the truck. Does anyone have any suggestions for tightening up the steering?
Old Oct 21, 2003 | 08:18 AM
Go Aweigh2452's Avatar
Go Aweigh2452
You obviously checked the fluid levels? Sounds like not enough fluid in the hydrolics to afect the steering ost likely. Also the tension on the belt but I think you may have a more serious pump problem if your fluid level is OK. Unlike the older Ford trucks, there are no screw down tighting nuts to adjust. Time to face the dealer with this one if everything else looks OK on the outside...
Old Oct 21, 2003 | 10:40 AM
bigdmizer's Avatar
bigdmizer
Fluid is fine, thanks for the advice. I guess to the Garage I go.
Old Oct 21, 2003 | 03:44 PM
warmdye's Avatar
warmdye
there is an adjustment nut on my steering box
Old Oct 21, 2003 | 04:45 PM
kehale's Avatar
kehale
Top of the frame mounted steering box. The adjustment rod (and locknut)
Find the directions on this site and have at it.
-T
Old Oct 21, 2003 | 08:38 PM
FortyFords's Avatar
FortyFords
Warning !!! Make sure all other steering components are tight and within spec before adjusting steering box.
did you chk all tie rod ends
ball joints
pitman arm splines
steering coupler to the steering box .
Rich
Old Oct 21, 2003 | 09:33 PM
V10BLOWN's Avatar
V10BLOWN
My brother had a Ford truck come into his shop the other day with some slop in the steering and he found the steel bushing in the aluminum steering wheel had started to slip. It appears to be welded into the aluminum, but on this vehicle it broke free and was giving a very sloppy feel to the steering.
Old Oct 22, 2003 | 06:36 AM
bigdmizer's Avatar
bigdmizer
very helpful, thankyou!
FordStolz68
May 4, 2016 09:08 AM
RDockery
Jul 26, 2015 08:11 AM
cory5517
Apr 3, 2014 08:53 PM
Speedjester
Dec 8, 2010 11:22 PM
abe
Mar 24, 2005 11:43 AM
