Bronco II Ford Bronco II
Steering Pump
Old Jan 7, 2004 | 05:08 PM
Ronin's Avatar
Ronin
Steering Pump
HI,
I have a 90 4wd automatic BII.
I had a leak in my sterring pump about a year ago,and i replaced it with one out of a 90 taurus. I have had problems with the power steering just leaving,no longer assisting me while turning the wheel, it would go out and come back during the turn.
I would go and look at it,check the fluid and it would come out really dark so i carefully drained it out and replaced it with fresh fluid,now it has been about 6-8 months since i replaced it last andI had to do it again last weekend,after a few days it smoothes out the steering, i filled it up this time with a more expensive fluid.
Is it possible that the pump isnt strong enough for my truck and its burning up, or is it just low quality fluid?
I dont know, what do you guys think?
Thank Alot!
Old Jan 7, 2004 | 06:39 PM
MJB's Avatar
MJB
Steering Box, proportional valve may be bad. Dirty dark fluid indicates high temperatures in the steering system. If the valve is bad fluid flow will be slowed causing an intermittent steering problem. Slow fluid would overheat causing it to fail to it's job. Viscosity is gone once fluid is heated.
Old Jan 16, 2004 | 03:47 PM
Ronin's Avatar
Ronin
Hi,
Thanks for helping me on that,what can i do to fix it? buy a new peice and drop it in? I dont think that the steering box is covered in my manual,where could i look for information on this?
Also,went to drive it today and when i turn the wheel,it is like it is grinding the gears. it vibrates really bad too i checked the fluid and it was green! ??
Well,Thanks for your help!
Old Jan 19, 2004 | 05:49 PM
Ronin's Avatar
Ronin
I went to a junkyard and got a used steering gearbox.they told me it was out of a ranger,didnt say what year, the receipt tells me it had a 2.8 engine. I got home and opened the box,there was black bad smelling fluid all over. I cleaned it up a little and then noticed it was coming out of the power steering pressure and return hose connections.Does this mean that this gearbox was burning fluid?
I noticed today that in the original gear the power steering fluid was still the new clear-blue color,while it was dark as i drained it from the reservoir.
Is it possible that the hoses are clogged somewhere so it is burning the fluid in the pump and not the gear?
Any help or advice will be much appreciated. Thank you
NewEnglandHerdsman
Nov 18, 2016 01:04 PM
JoeF250
15
Sep 29, 2016 07:38 AM
08F250SD_Laredo
Jan 19, 2016 09:08 PM
jcweis1
Mar 28, 2015 09:42 PM
DMEMONT
1978 - 1996 Big Bronco
May 31, 2004 05:01 PM
