Winter Thermostat
Old Jan 4, 2013 | 06:04 PM
bgab3's Avatar
bgab3
Winter Thermostat
I bought my truck used and there was this thermostat in the glove box. I live in Canada and the winter temps can get pretty low (over-10 F). I am assuming that the X192 means that the thermostat opens at 192 degrees. So what I am wondering is what does a stock thermostat open at. My work is only a 10 minute drive so I would like my truck to run a bit hotter in the winter.
The thermostat has X192, 16 and LO stamped on it. I have a picture of it but I can't figure out how to unload it on here.
Old Jan 4, 2013 | 06:12 PM
bashby's Avatar
bashby
192 or 195 is stock, I believe. Hard to tell what you have in there now.
Old Jan 4, 2013 | 06:26 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Diesels don't like short drives like that in winter. They never fully warm up!
But yes, stock is 192, and if your not overheating, or running to cold, chances are you have the right one in there, as only a Ford or IH thermostat will work right in these engines.
And with how much trouble it is changing a thermostat in these, I sure wouldn't bother changing it seasonally!
But heres an easy to install/remove winter thermostat
Old Jan 4, 2013 | 06:43 PM
bgab3's Avatar
bgab3
Alright thanks. I do realize that short trips in cold weather are hard on engines, specially diesels. I am currently running the exact same winter cover as you with the flaps closed.
Old Jan 5, 2013 | 07:05 PM
Wild Ziggy's Avatar
Wild Ziggy
Where does someone find a winter cover like that?
Old Jan 5, 2013 | 07:10 PM
Raleigh1's Avatar
Raleigh1
I had mine custom made by a local canvas shop.
https://www.ford-trucks.com/forums/1...in-winter.html
Old Jan 5, 2013 | 08:17 PM
madpogue's Avatar
madpogue
For your '90? FIA WF922-1 Custom Fit Winter Front And Bug Screen : Amazon.com : Automotive
cyclemanb
Jun 16, 2017 01:46 PM
John - NNY
Jul 8, 2011 09:31 PM
cutlass
51
Jun 16, 2011 12:54 PM
Diabolic
1983 - 2012 Ranger & B-Series
25
Mar 10, 2004 08:51 PM
blownbronco
1978 - 1996 Big Bronco
Dec 4, 2002 03:45 PM
