project ideas and help
Old Jan 3, 2013 | 12:14 PM
USArmyTaterness's Avatar
USArmyTaterness
Ok so I needed a project for my chassis fab class and my wife told me to take her truck and turn it into a street rod
76 f100 390 motor with a t18 4spd
What she wants is a streetable daily driver type deal so my initial thoughts were to box the frame give it a slight rake possible airbag conversion and throw a 9 in in the rear the big project I was thinking was a mustang 2 front end keep in mind reall the only pre fab things I can go too would be things like the airbags themselves
My question is who has done something like this what am I going to run into pictures of suspension fuel tanks and such or if you have ideas that would be nice as well
Old Jan 3, 2013 | 08:03 PM
USArmyTaterness
I see yall lookin.
Old Jan 3, 2013 | 09:43 PM
teds74ford's Avatar
teds74ford
Not sure how deep you want to dive in, but how about just drop front beams, but boxing/ 4 link rear?
Old Jan 3, 2013 | 10:01 PM
USArmyTaterness
This is supposed to be a major construction project. So it is going to be rather extreme compared to most projects.
I do not mind the extra work required more quality work just means mine is just that much different than the others
Old Jan 3, 2013 | 10:34 PM
HIO Silver's Avatar
HIO Silver
Ideas? I spend too much time thinking of them...
A 66-77 Bronco Roadster
2WD with a 302/C4 or a 302/T-5 manual
Frame: 3/16th steel boxing plates with dimple-died holes... see image below. They are also referred to as "speed holes".
Suspension: Front - Mustang II style using Paul Horton Welder Series components. Rear - Triangulated 4-link using an 8.8 out of an Explorer
'need to fab a trans/driveshaft tunnel.
Body?... stock!!!
How about a Bumpside or Dentside Nomad??
https://www.ford-trucks.com/forums/8...ml#post7014028
Or a 2WD Bump/Dent crewcab with a shortbed... ala Ford's Sportrac.
Last edited by HIO Silver; Jan 3, 2013 at 10:36 PM. Reason: 'dunno why it's attaching the third photo.. I'm not privileged to do attachments. Your guess is as good as mine.
Old Jan 4, 2013 | 09:22 AM
USArmyTaterness
I like some of your ideas I had played around with using an explorer rear end but both my wife and I prefer something solid in the rear so I was thinking the fab 9 with a fourlink that frame piece don't look too bad gives me a couple ideas definitely going to try to go with the mustang 2 front
Old Jan 4, 2013 | 09:42 AM
mikeo0o0o0's Avatar
mikeo0o0o0
What about adding a Crown Vic front suspension? Inependent front suspension, rack and pinion steering and several inches lower.
Here's a link to one members on going project:
https://www.ford-trucks.com/forums/1...sion-swap.html
Old Jan 4, 2013 | 03:07 PM
USArmyTaterness
I started looking through that it looks good I will have to read through more tonight when I'm not on ly phone
WncLee
13
Apr 6, 2017 03:27 PM
snowxr
Jun 26, 2015 08:49 PM
HillBillyBuddha
Apr 14, 2014 07:12 AM
dron_jones
May 2, 2013 11:32 PM
Bigryan79
Dec 19, 2009 06:48 AM
