COLD WEATHER
Old Jan 4, 2013 | 05:16 PM
  #31
SavageNFS's Avatar
SavageNFS
Originally Posted by CountryD
The coldest Ive seen it in Vernal Utah, is -33.
That's man cold...
Old Jan 4, 2013 | 09:44 PM
  #32
Painted Horse's Avatar
Painted Horse
Originally Posted by Northof62
I don't think pm22 has anti gel, I believe you need pm22a in cold temps.
None of the PM22 products has the anti-gel. PM23 has the anti-gel, PM22a vs PM22b are USA vs Canadian products.
The Uinta Basin ( vernal area) is almost the coldest area of the state. Usually the Peter Sinks area north of Logan gets colder and holds the records. But nobody lives in Peter Sinks, So the only people that care about it are the snowmobilers. The problem with the basin are those winter inversons that trap the cold air.
Old Jan 5, 2013 | 09:15 AM
  #33
dmags's Avatar
dmags
Do any of you add anything when you use fords anti gel juice?
I use the anti-gel but it doesn't have cetane boost correct?
Old Jan 5, 2013 | 11:36 AM
  #34
GobblinTom's Avatar
GobblinTom
You ever try the Power Service in the white bottle?
Old Jan 5, 2013 | 12:06 PM
  #35
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
My truck sees -40F all the time and I haven't had any problems with the DEF.
That is just too damm cold. So do you have any extra protection on your fuel system or do you just run the winter additive?
Im in North Eastern Utah. Moved here from Tn. So, Im new to the REALLY cold weather. Coldest Ive seen it in TN was +8. The coldest Ive seen it in Vernal Utah, is -33. So, thats a BIG difference in what Im used to.
Sure glad I don't see them low of temps. Here in North Central Washington it's more like your Tn weather. I don't think it even dropped to zero last year. I run the Power Service in the white bottle. In my 7.3 that is all a ran in my new truck I have been running the PM22 but with this next tank I will switch to the Power Service for winter.
Cheers
Old Jan 5, 2013 | 03:16 PM
  #36
Northof62's Avatar
Northof62
Cheers
It is cold! I wouldn't trade it though. The only I do is put on the winter front and add pm23. Thanks Painted Horse, I store that stuff in my own container so I guess I forgot what it was called.
Old Jan 5, 2013 | 04:06 PM
  #37
mountainhoundf350's Avatar
mountainhoundf350
Pics where'd you get it?
Old Jan 5, 2013 | 04:39 PM
  #38
marchare011's Avatar
marchare011
Hmmm, bet I know why the town got that name.
Grey Power Service in the summer, white in the winter. NEVER EVER USE THE RED BOTTLE 911.
Old Jan 5, 2013 | 05:22 PM
  #39
Northof62's Avatar
Northof62
I got it from a place called Alaska Tent and Tarp. They custom make them to fit your vehicle. I'll post some pics next time I'm home.
Old Jan 5, 2013 | 05:52 PM
  #40
CountryD's Avatar
CountryD
I guess the Optilube is working, it was -13 here last night and +1 today, and she started rite up this morning and I drove her about 60 miles today and she ran like a CHAMP. Gonna stick with Optilube.
Old Jan 7, 2013 | 10:05 AM
  #41
spadasak's Avatar
spadasak
I had the same issue with the engine light coming on after using the block heater. After researching the codes, one of which was P0181, I found that there is a temp sensor that compares the temp of the engine with the block heater. Something like that, anyway if there is a large difference for three starts in a row then it throws a code. I was told NOT to use the block heater for anything above 0 degrees F.
Old Jan 7, 2013 | 04:34 PM
  #42
marchare011
Guess I better take my truck to the dealer then cuz it must be broke. I use my engine/block heater routinely when it's 20 degrees and it's not throwing a code. No jinx, no jinx, no jinx.
I'm not poking fun at you, only your advisor. I don't buy that. Who told you that?
BTW, Welcome aboard.
Old Jan 7, 2013 | 06:11 PM
  #43
CountryD's Avatar
CountryD
YEP, thats one of the codes that I had, but FORD has a new download for that particular code. The dealer said that when you use the Plug for days at a time, that I needed the new download or it would keep throwing the same code.
Old Jan 8, 2013 | 06:36 AM
  #44
spadasak's Avatar
spadasak
I used to plug my vehicle in at anything below 20 degrees F, but now only bleow 0 degrees F. I understand that it looks at temperature in 10 hour increments and if there is a large difference between what the computer measures and the block then you get a wonderful code. It sure is nice to get into a warm vehicle, but I guess when you pay $70k for a truck that is just asking too much!
Old Jan 8, 2013 | 10:05 PM
  #45
cyclebert's Avatar
cyclebert
I like to plug in my block heater. It gets cold in Saskatchewan. I've had the engine light come on from using the block heater (code P050E if I recall), which I reset with an OBD meter. My reverse sensors also go screwy when "iced".
