Shift indicator????
Old Jan 2, 2013 | 03:59 PM
mustangsallysdad's Avatar
mustangsallysdad
Shift indicator????
2005 Ford Expedition with only 22,500 miles...went to place it in park this morning and the indicator will only go as far as "R". It shifts and functions fine, but is off by one position. Anyone had this problem and know how to repair? Thanks.
Old Jan 2, 2013 | 04:09 PM
alloro's Avatar
alloro
The plastic adjuster mount under the dash probably broke.
Old Jan 2, 2013 | 05:26 PM
mustangsallysdad
Took the lower column cover off and don't see anything out of sorts...ideas?
Old Jan 3, 2013 | 02:28 AM
alloro's Avatar
alloro
You're looking for what the red arrow in this picture is pointing to.
https://www.ford-trucks.com/forums/9...ml#post8299416
Old Jan 3, 2013 | 05:51 PM
mustangsallysdad
Any other ideas? I've removed the lower dash as well as the upper and lower column covers...have good access. The adjuster is not broken and seems to work well throughout it's travel. The little red (or purple) wire that runs through the black tube up to the indicator is intact but has slack on the end that attaches to the shift lever. I've lightly tugged on it to ensure that it's not broken. Pulling on it by hand does move it down in the selector. The problem seems to be that it is not retracting back into the black tube far enough to allow it to reach "P". Adjusting it all the way in and out doesn't solve the problem. I've searched the forums and it seems that most of the remedies suggested are for models prior to my 2005. Help!
Old Jan 5, 2013 | 12:26 PM
mustangsallysdad
So...does the lack of responses indicate that no one else has encountered this problem?
Old Jan 5, 2013 | 03:06 PM
alwaysfords41's Avatar
alwaysfords41
You didn't seem interested in years prior to 05. My 04 which is very likely the same as yours uses a spring to return the indicator to the left (it is driven to the right by the shift lever). In my particular case the spring broke which prevented the needle from returning to home.
Old Jan 5, 2013 | 03:16 PM
mustangsallysdad
Thanks...that would make sense. Can you guide me a little more. Where is it located, how to get to it, etc?
Old Jan 5, 2013 | 03:20 PM
alwaysfords41
I had the dealer fix it - I didn't have the time for a project at the time.
Old Jan 6, 2013 | 10:57 AM
tulswa's Avatar
tulswa
I had the same problem with my '06. i bought it from Carmax and had them fix it, along with a couple of other squwaks, within the 30 day fix anything window. The problem resurfaced around 6 months later and saw the thread that alloro mentions. Mine had slack and I adjusted it but I seem to remember that I found that the cable had slipped off of a wheel between the point in the photo and the indicator. I also shot some lubricant into the cable.
BrittsNFords
17
Jul 12, 2021 08:51 AM
Vegas Ernie
1983 - 2012 Ranger & B-Series
Apr 25, 2014 12:13 AM
Roostersutton
Aug 12, 2013 08:25 PM
Hairfarmer
Jul 14, 2006 06:37 PM
bigmike09
Sep 26, 2003 01:11 PM
