Can't start in cold without plugging in
Old Jan 2, 2013 | 09:50 AM
Travis20027.3's Avatar
Travis20027.3
So first guess was glow plugs.. they all looked brand new so I put them all back together and am hoping someone has an idea where to look next to solve the issue. Starts fine when I plug it in and was starting fine till it got colder. It isn't horribly cold where I live either, Las Vegas NV, bout 30-50 varies a lot here.
Old Jan 2, 2013 | 09:53 AM
Travis20027.3
2002 7.3 guess that would help
Old Jan 2, 2013 | 10:10 AM
rufushusky's Avatar
rufushusky
Did you check your Glow plug relay? Those die with great regularity?
Good link on possible issues...
Troubleshooting GPR & GP's - Ford Powerstroke Diesel Forum
Old Jan 2, 2013 | 01:26 PM
Brother Les's Avatar
Brother Les
Describe how your truck turns over. Starter winging over or very slow? Have you charged up your batts and had them load tested? You may get a reading of 12volts when you first try to start your truck. When you turn your key on, the GPs will drop the voltage to 11v. The truck has to have at least 10.5v to start. If it is below this then you are not going to start.
Old Jan 2, 2013 | 01:47 PM
Tugly's Avatar
Tugly
Last links in my signature can be helpful.
Old Jan 2, 2013 | 04:56 PM
Travis20027.3
Thank you, Rufus, I am going to give the relay a test to see if that is it.
Les, the batteries were just tested when I replaced my alternator a couple weeks back and they are good.
Walleye Hunter
50
Dec 15, 2017 08:43 AM
choskins
Oct 24, 2016 01:21 PM
SGorman13
30
Feb 26, 2014 05:26 AM
PJ-Hunter
24
Dec 11, 2013 05:49 PM
BEAST428
Sep 9, 2003 10:15 AM
