an AN question
Old Jan 1, 2013 | 11:10 PM
FoundOnRoadDominatin's Avatar
Question an AN question
when talking about -(6,8,10) AN's in regards to the carburetor and the rest of the fuel system, whats better -6,-8 or -10? Does the whole system have to be the same or does it gradually decrease or increase? For everday use and some 4x4ing what should I be looking for?
Old Jan 1, 2013 | 11:23 PM
f100beatertruck's Avatar
f100beatertruck
AN Numbers relate to their size. An AN-8 is actually 8/16's in diameter or 1/2". AN-10 is 10/16's or 5/8".
It's commonly called a dash 8 line or dash 8 fitting, you don't have to say AN dash 8. And AN stands for Army/Navy as it was invented before the airforce existed. The development comes from the military where a dependable, solid connection is desired. Also, the flare is 37* vs SAE's 45* flare so the two are not compatible. You will also need a separate flaring tool for AN hardline. They are all single flare and you do not use seamed lines. They'll split on the seam. Seamed lines can be double flared for an SAE connection however. No teflon tape or sealant on AN fittings either.
One isn't necessarily better than the other - you get the size you need.
Old Jan 2, 2013 | 01:03 AM
how do you know which size exactly you need
Old Jan 2, 2013 | 04:27 AM
CountryBumkin's Avatar
CountryBumkin
Just consider the stock size fuel line and match it or go up one size. Most fuel systems are 5/16 or 3/8" lines/hoses, so play it safe and use a -6.
If you have a high performace big-block engine, you could go to a -8 line but that's the biggest you would ever need. Of course it doesn't hurt go bigger, except for your wallet.
Old Jan 2, 2013 | 07:11 AM
f100beatertruck
Oh, I forgot to mention but AN line is measured by the OD and flexible tube by the ID.
And I agree, a -6 line would be sufficient for almost all small blocks and most big blocks. There are race guys running 8's in the 1/4 (8-900hp) using -6 lines...
Fuel systems are one of the area's where the classic cliche "if some is good and more is better, way too much is just about right" comes to mind. Even I got caught up in it running -8 on my 450hp Chevelle... Waste of money.
Old Jan 2, 2013 | 07:50 AM
86fordtruck's Avatar
86fordtruck
I concur. My EFI system came with -6 lines and is good to 550 hp. I doubt you will need more than that. The narrowest part of you line is probably the fuel tank sending unit so I wouldn't go any bigger than that.
Also, they make adapters to go from AN fittings to NPT fittings, etc. There are a ton of adapters out there.
Old Jan 2, 2013 | 05:45 PM
81ChopTop's Avatar
81ChopTop
I'll bit on this one too. For my build, I'm running a -6 line for fuel. This will be hooked up to run a 460 and I'm confident I will never have a fuel starvation issue (even when the new engine is built).
Old Jan 3, 2013 | 10:03 AM
Thanks guys for all your help. I know now that for my 302 running a 600 cfm carb the -6 line should be plenty enough. now a lil different question, would 2 inline filters to the carb be too much?
Old Jan 3, 2013 | 04:31 PM
81ChopTop's Avatar
81ChopTop
Never hurts to have secondary filtration. I know there's a few on here that run two filters.
F-250 restorer
Jan 21, 2017 08:59 AM
Ford4Life7.3
Dec 22, 2013 01:07 AM
davidsca
May 20, 2006 11:35 AM
barebackjake
Nov 25, 2005 12:48 PM
rmalottwtes30
Oct 18, 2005 11:42 PM
