Making P/S Lines Help
Old Jan 12, 2017 | 04:34 PM
F-250 restorer's Avatar
F-250 restorer
Can someone pls give me a general guide, for making the braided, high pressure lines from a Saginaw pump. I will figure out the end size and angles, just needed to know the size of the line, who makes the best fittings for diy, and where to buy it.
Old Jan 12, 2017 | 04:36 PM
SparkyAl's Avatar
SparkyAl
I've always just gone to NAPA, they had a book that would tell them the length and size of the hoses and the equipment to make them.
Old Jan 12, 2017 | 05:11 PM
HIO Silver's Avatar
HIO Silver
PSC Motorsports.. field serviceable too!
Performance Offroad Power Steering, Howe Performance, Trail Gear, Full Hydraulic, Ram Assist
Old Jan 21, 2017 | 12:28 AM
F-250 restorer
Surely someone knows the size of the line used--AN 6, AN 8? and the fittings needed?
Old Jan 21, 2017 | 08:50 AM
78 PEB's Avatar
78 PEB
Old Jan 21, 2017 | 08:51 AM
78 PEB's Avatar
78 PEB
Just for reference when dealing with AN sized lines........The AN size denotes 16ths of an inch.......so a -6 would be 6/16ths........or 3/8's.....I just built lines for my 4BT conversion that utilizes a Saginaw pump. The return line was easy......ordered a chunk of bulk 3/8 PS return line from Rock Auto. Both the pump and the old return line at the P/S gear were just common bubble style hose barb on the tubes.........cut hose to length and used a couple of hose clamps. The pressure side was a bit more involved. I had the pressure hose that came on the Saginaw pump from the Dodge and I had the pressure hose that was on my original 351M pump. I used the metal tube portions from both those pressure hoses. I cut the tubes then found some male -6x1/2 NPT nipples that I could cut off the NPT portion and leave the hex for a wrench on the -6 piece. I then re-bored the hole thru the -6 pieces to just slightly larger than the OD of the tube portions I needed to use. Then I inserted the tubes into the holes I just bored and brazed them up. Then all I required to get from the pump to the gear was the correct length -6 hose with female ends. I have heard that NAPA will build custom P/S hoses, with what ever mix and match ends you need. However, I want to build this truck so that if I am in BFE and happen to blow a hose....I can find something.....not be stuck there for a week while I wait on custom parts. You can always find someone to build a simple JIC hose......if one of my custom tube portions fails.....I order the appropriate hose assy. ('78 Ford or '95 Dodge) take it to a local mom and pop repair shop (or a farm shop, or construction company shop etc.) and have them braze a -6 nipple on and go.......Hope this all made sense, there are some pics above of my hose setup.......
Old Jan 21, 2017 | 08:59 AM
78 PEB's Avatar
78 PEB
As far as getting a braided stainless hose built......google "hydraulic hoses" for your area......if that fails walk into some of the local heavy equipment or farm equipment dealers or heavy truck shops......and start asking questions......its all pretty common stuff in that world.....
thendrix
Mar 24, 2017 02:22 PM
bronco2fan
Bronco II
Nov 21, 2010 05:11 PM
G2IC_Wraith
Jun 12, 2006 02:46 PM
davidsca
May 20, 2006 11:35 AM
Tx_Atty
Apr 27, 2006 02:07 PM
