1989 fuel injection - multiport ?
Old Jan 29, 2004 | 12:22 AM
carpe_diem's Avatar
carpe_diem
Is my 89 F250 EFI multiport or throttle body?
It looks like it has multiple injectors and no TB, which leads me to believe it is multiport but I wanted to confirm this.
What exactly is the difference between the two types?
MP EFI has been introduced in 88 and prior to that, TB has been used - at least on cars. That's another question, is there any difference in MP EFI on cars and trucks?
Old Jan 29, 2004 | 07:15 AM
EPNCSU2006's Avatar
EPNCSU2006
The '89 should be multiport injection - multiport was first used in '87 on the 4.9 and 5.0, and '88 on the 5.8 and 7.5. Throttle body injection is more similar to a carburetor, with a throttle body sitting flat on the intake manifold much like a carburetor would. The injectors, usually 2-4 of them sit on top of the throttle body. Multiport has a single injector for every cylinder in the intake runner for each cylinder. There is still a throttle body, but it is mounted vertical at the front of the intake manifold. There are two basic types of multiport injection. The truck systems were batch fire, where 4 injectors are fired at the same time. Later trucks with mass-air systems fired each injector individually when the intake valve opened for that cylinder (sequential EFI or SEFI). Most cars with multiport were SEFI, both speed density and mass-air. That's the biggest difference between the cars and trucks, is the cars are mostly SEFI, while most trucks are batch fire.
Old Jan 30, 2004 | 11:52 AM
LxMan1's Avatar
LxMan1
The MPI was first used in 86 on 5.0's in trucks and cars.
It still has a throttlebody on the front of the intake where the air tunes from the air filter box run too. It is called multi-port injection because there is an injector for each cylinder.
Throttlebody injection just has 2 injectors in the throttlebody itself and the intake is set up like a carburated engine.
Jimmy
Old Jan 30, 2004 | 01:00 PM
carpe_diem's Avatar
carpe_diem
Interestingly, my 93 Caprice with 5.7L and EFI has throttle body injection (looks like a carburator with 2 injectors), while the 89 Ford truck has MPI (8 injectors for each cylinder).
Have they made any advances in EFI over the last 10 years?
Old Jan 31, 2004 | 08:36 PM
LxMan1's Avatar
LxMan1
Yes, Chevy was way behind the times. They used the old outdated TBI long after Ford did.
Late 90's I believe.
Old Feb 1, 2004 | 10:58 PM
carpe_diem's Avatar
carpe_diem
Interesting.
1925mosin
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
15
Jan 6, 2016 08:57 PM
Club Wagon
Jun 5, 2007 08:36 PM
fordtrck302
Electrical Systems/Wiring
Feb 22, 2006 05:26 PM
ddman1
1983 - 2012 Ranger & B-Series
Oct 22, 2004 06:06 PM
Chauc3r
May 11, 2004 01:46 PM
