2013 Knee-deep BS thread!
Old Feb 5, 2013 | 09:27 AM
  #1696
Jigger2020's Avatar
Jigger2020
I hate all that rain, its depressing
Old Feb 5, 2013 | 09:33 AM
  #1697
fabmandelux's Avatar
fabmandelux
Morning Mat. Ya, the rain would make me depressed enough to commit suicide. That's why I like living over here in the desert........
Old Feb 5, 2013 | 09:42 AM
  #1698
Jigger2020's Avatar
Jigger2020
ME too Don, like we were talking about before either sun or sun lamps really helps my moods
Old Feb 5, 2013 | 09:50 AM
  #1699
fabmandelux
That's one of the reasons we picked this house to buy and remodel. Our living room, bedroom and my office all face due South. When the sun rises in the morning it FLOODS my office with sunshine, and I can feel the change in my mood. I have a "sun" box for the few times the sun isn't shining. Makes a HUGE difference to my PTSD......
Old Feb 5, 2013 | 09:52 AM
  #1700
67nukeford's Avatar
67nukeford
Veteran: Navy
Good monring Don and the Oregon gang, happy Tuesday! Knee seems to be doing really well, hopefully won't need any pain meds today.
Old Feb 5, 2013 | 11:09 AM
  #1701
Matthew_B's Avatar
Matthew_B
If you can avoid it that's great Pat. A buddy of mine had a full knee replacement, and he said the hardest part of the whole process was weaning himself off the Oxy.
Old Feb 5, 2013 | 11:11 AM
  #1702
Matthew_B's Avatar
Matthew_B
I like Fords - that's why I have two for the two vehicles I drive and I'm about to have 3.
I do have my gripes though. What's the deal with the engineer who does the climate control? You only get A/C blowing out the dash or on the window. Over here in the rain forest we like A/C to dry out the interior, but I get tired of it blowing in my face. Would it really be that hard to give us a separate button?
Old Feb 5, 2013 | 11:23 AM
  #1703
kjvforme's Avatar
kjvforme
Morning Everyone, good to hear your on the mend Pat. Snow in the ofrcast for here on Wednesday through Friday, we'll see if that happens.
I pulled the plugs on Rattle (62 4x4) and did a compression check yesterday. Here are the results:
#1 120
#2 110
#3 118
#4 112
#5 120
#6 125
15 psi differential, manual says 5 PSI, but I have always gone with 15PSI max diff, what do you guys think, and the plugs were clean no oil on them. Going to pull the valve cover and adjust up the valve lash today if weather permits.
Old Feb 5, 2013 | 11:30 AM
  #1704
fabmandelux
Morning Pat, Mat, and Rob! Just got back from putting out a fire in one of my forums. Damn Nubees.........
Not bad for an old engine Rob. I wouldn't worry about a 15lb differance.....
Old Feb 5, 2013 | 11:37 AM
  #1705
kjvforme's Avatar
kjvforme
yeah thats what I was thinking Don. I need to pull the intake and exhaust manifold off. The heat riser valve is stuck and pin sheared on the weight side. Found the forward freeze plug leaking and the one under the center of the manifolds has got some weird looking plug system. Most likely to fix a leak without pulling the manifold.
Projects for later, replace the leaking engine side cover gasket and do a clutch kit on it.
That engine starts right up after going through the carb and idles perfect, it does have a miss at idle but not at high end.
Old Feb 5, 2013 | 12:15 PM
  #1706
fabmandelux
Just sent the bill to the LLC for the clean-up of the crazy lady's house. Just over $5,500, and we hauled off over 8 TONS of crap to the landfill........
Old Feb 5, 2013 | 12:25 PM
  #1707
kjvforme's Avatar
kjvforme
They got off cheap, if that had been done by a contractor, ouch!
Old Feb 5, 2013 | 01:15 PM
  #1708
TinyWonder's Avatar
TinyWonder
Morning Oregon FTE gang and friends.
Pat, I'm glad to hear that you are doing well.
What a crazy day here at work. I'm super busy. I almost had to put one of my co-workers in their place first thing. Some people just don't know how to let others do their job and worry about their own stuff.
Old Feb 5, 2013 | 07:41 PM
  #1709
bertha66's Avatar
bertha66
Evening all, not much else, glad you are doing good Pat.
Old Feb 5, 2013 | 08:34 PM
  #1710
kjvforme's Avatar
kjvforme
Evening guys, spent part of the day working on the 62 4x4. Pulled the, rocker cover off and adjusted the,valve lash. she sounds a lot more quiet. Took my mechanics stethiscope and listen around the engine block area was quiet, the only area was the Delco alternator. Someone switched out the geneator before I bought it.
