1978 - 1996 Big Bronco
88 EFI 300 running rough
Old Feb 2, 2013 | 07:02 AM
  #31
Twistedwrench's Avatar
Twistedwrench
Originally Posted by Black Ford XLT
Big ugly , prior to all this was the bronco sitting for a extended time or were you using it as a Dailey driver, I too am from sc, when I let my truck sit (extended)it experiences the symptoms you describe.This only happens during the summers months.Humidity causes this water in fuel tank .TR
In addition to that , there is the possibility that there is rust in the injector rail partially plugging the screens in the injectors. What are your fuel pressure readings , dead cold and hot ?
Old Feb 5, 2013 | 01:06 PM
  #32
Twistedwrench
Under the dash next to where the clutch pedel is/ would be is the inertia switch , this switch breaks the electrical connection to the fuel pump(s) in the event of a crash . Sometimes the contacts get screwed up and there isn't a good connection . There is a red button you push to reset it . Try and reset the switch .
jemini
15
Aug 26, 2016 07:36 AM
Richard Olshefski
Apr 21, 2014 11:01 AM
dpayne1976
Mar 2, 2008 02:29 PM
lucky3380
Dec 7, 2004 10:00 PM
Marc150
Feb 17, 2004 06:46 PM
